General Forums => The Mess Hall => Topic started by: jeepfourlow on August 23, 2005, 05:28:49 PM
So i installed a 1" daystar body mount lift and now when i shift to 2nd the shifter is hitting the seat...is there anyway to correct this? Also, i was thinking about getting the B&M Ripper shifter, would i have more complications if i did get it? thanks for any help.
You could take the stick off and bend it for clearance. Probably run into similar problems with the B&M.
The B&M should cure the problem as it has a lot shorter throw. But then again I need to bend my B&M shifter to get it right. Got mine off Ebay so it was likely bent before I bought it.
hey is the shorter throw noticeable over stock?
Very, it's a very tight pattern.
Mine is a 1" spacer for the shifter base, and a stainless steel shift lever.
whats the 1" spacer for?
sorry but im a newb
The B&M ripper is very tight comparison to stock. It should work without modification. I have a 3" body lift and the ripper shifter and I have no problems with clearance issues.
Hmm, maybe I'll have to consider one of these. I lose a lot of power shifting to 5th because of the length of the throw. The stock setup is pretty good for a 5000 RPM powershift through the lower gears though.
