General Forums => The Mess Hall => Topic started by: damon54 on April 15, 2007, 04:55:43 PM
I just tore my motor down to the block. Everything came apart easy exce[t the oil dipstick tube. Is there anyway to get that thing out? Also does anyone have a good line on ordering some forged pistons? And who has the better cam sets Clifford or Hesco?
I dont know wich is better but I realy like my hesco RVOB cam and bennie was very help full.
Do they have a kit that comes with it? Hydro lifters, springs and rods?
I dont think they sell a complete kit but I bought the cam which came with the lifters and also bought a double roller timing chain kit,roller rockers,adjustable fuel pressure regulator and stronger valve springs.You have to have the head machiend for the new springs so I had them smothe out and match port it also a valve job and mill the head surface.hope this helps
How much did all that cost you? I just dropped the block at the machine shop and picked up a set of 33's on rims, so there goes a lot of money. I will probably get that set up like yours as well. I need to ask them about custom push rods because the head and the block will be shaved. Are the roller rockers adjustable? I also went with hyperutectic pistons instead of forged, they should be strong enough and they cost a third as much.
Yes hescos roller rockers are adjustable.I dont remember a total but I think I droped around 1500 or 2000 buy the time all was said and done.
Thanks for the info. I'll get started with that after the block is finished.
BTW did you regear?
Yes I am running 4:88's
