General Forums => The Mess Hall => Topic started by: damon54 on June 14, 2007, 02:35:49 PM
Title: Rod Bolts
Post by: damon54 on June 14, 2007, 02:35:49 PM
Anyone know where I can get a set of rod bolts for the 2.5?  ARB dosen't have them and the dealership can't get them.
Title: Re: Rod Bolts
Post by: wrangler387 on June 15, 2007, 06:16:13 PM
Try clifford or hesco. I'm not going to be suprised if they are the same bolts as the 4.0L ones.
Post by: Jeffy on June 15, 2007, 07:40:42 PM
Right there in the FAQ under Mopar Performance Parts List.
Connecting Rod Bolts: #P4529816     2.5L & 4.0L
Post by: damon54 on June 15, 2007, 09:16:24 PM
Hesco does not have them.  The ones from the 4.0 are different from what I have been told.  Jeffy do you think I will still be able to get them at Mopar if the dealership says they are discontinued?  According to them it only comes with the whole rod setup.
Post by: Jeffy on June 15, 2007, 10:43:21 PM
Hard to say but if they are indeed shared with the 4.0L, then they might have them.  The 4.0L wasn't discontinued that long ago.  Just one year ago.
I'd suspect any engine rebuilder will have them or can get them.
Post by: wrangler387 on June 15, 2007, 10:46:26 PM
Send your bolts into ARP if you can't find them anywhere else, they will either match it up with something else they have, or make you some. Or if they already make 4.0 bolts you can ask them for the specs on it and measure it against what you have.
Post by: damon54 on June 16, 2007, 07:02:01 AM
The guys over at Hesco told me the bolts from the 4.0 are different.  I may have to have them custom made.
Post by: Jeffy on June 16, 2007, 03:25:43 PM
What's 'different' mean?  Mopar Performance lists the 4.0L and the 2.5L together.  Why would Hesco use out of spec fasteners?
If your engine is already apart then measure your existing stuff and have them compare them to the other fasteners.  It's lot like they are they are specific to the 2.5L and only the 2.5L.  I'm sure an engine shop would be able to source them.
