General Forums => The Mess Hall => Topic started by: Oilsmoke on July 22, 2007, 02:00:49 PM
Title: Rig Rater Score
Post by: Oilsmoke on July 22, 2007, 02:00:49 PM
Lets Start a List. Be honest. Keep it fun. Get your score here www.rigrater.com (http://www.rigrater.com)
291RRv1.0 with a BOA of 15.74
Title: Re: Rig Rater Score
Post by: aw12345 on July 22, 2007, 02:30:06 PM
Well here is mine
498RRv1.0
Your Break-Over Angle (BOA) is 23.98 degrees
Post by: jcsanders79 on July 22, 2007, 02:55:11 PM
594RRv1.0
Your Break-Over Angle (BOA) is 22.01 degrees!
Post by: Jeffy on July 22, 2007, 04:07:51 PM
My RigRater (http://"http://www.rigrater.com") Score: 700RRv1.0 with a BOA of 21.37
Post by: Bounty Hunter on July 22, 2007, 06:12:37 PM
673RRv1.0
Your Break-Over Angle (BOA) is 24.00 degrees!
Post by: gomi on July 23, 2007, 05:32:28 AM
1,000,000 for driver hawtness.....haahahaa just kidding!
Post by: DodgeMudder on July 26, 2007, 02:38:24 PM
634RRv1.0
Your Break-Over Angle (BOA) is 35.50 degrees!
Post by: Air Sierra on July 30, 2007, 08:55:27 AM
794RRv1.0
Your Break-Over Angle (BOA) is 35.13 degrees!
Post by: Mozman68 on July 30, 2007, 09:06:31 AM
X2...for me that is... :blbl:
443RRV1.0 for my pre-build (didn't include the new axles or tires or protection since they aren't on yet.  Will do another one later)
EDIT:  Post build-up (including new engine) ----- 969RRV1.0....I'm so bad-ass it's scary.... :blbl:
Post by: jeepheap on July 30, 2007, 09:24:49 AM
my daily yj 378RRv1.0 with boa of 18.92
my dj 839RRv1.0 with a boa of 30.57
Post by: neale_rs on July 30, 2007, 02:08:04 PM
For the '95 YJ:
330RRv1.0
Your Break-Over Angle (BOA) is 12.51 degrees!
Needs work!
For the '43 GPW:
295RRv1.0
Your Break-Over Angle (BOA) is 16.26 degrees!
This does not seem to be the BOA that is usually reported.  Usually you see values about double these for stock short wheel base jeeps.
Post by: Oilsmoke on July 30, 2007, 05:02:20 PM
Mozman68 Where is your BOA?
Post by: Bounty Hunter on July 31, 2007, 02:25:50 AM
For you guys with the 30º+ BOA, what is your wheelbase/tire/lift setup?  What about the belly skid or any clocking?
Post by: Mozman68 on July 31, 2007, 07:38:50 AM
Woops...I didn't copy the fancy info they provided...just typed in the number myself.  Let me check again for both setups.
OK...my boa AFTER my suspension mods are done in a few months will be 26.64.
The belly up skid will help...extending my wheelbase a few inches won't...but I don't have too many breakover issues when trail riding in MI.
Post by: Oilsmoke on July 31, 2007, 02:55:34 PM
IN MI, come on. I hear the Dirt clods are that Big . :smile:
Post by: Jeffy on July 31, 2007, 03:10:00 PM
So what's the actual score?  :blbl:
Post by: Oilsmoke on July 31, 2007, 07:16:56 PM
I worked on the jeep some and Redid the rater and here is my New Score.
317RRv1.0
Your Break-Over Angle (BOA) is 15.74 degrees
Work is Progress is for sure
Post by: Mozman68 on August 01, 2007, 01:32:31 PM
I provided both...smartass... :twofingers:
Post by: Jeffy on August 01, 2007, 03:27:47 PM
I don't see a current BOA.  :confused:
Post by: Mozman68 on August 01, 2007, 04:27:00 PM
23.72...bah :bandit:
Post by: Jeffy on August 01, 2007, 04:28:47 PM
How high up is your tcase skid?
Post by: Rokcrwln on August 01, 2007, 07:50:12 PM
My RigRater Score: 705RRv1.0 with a BOA of 21.49  --
Post by: jcsanders79 on August 01, 2007, 08:36:05 PM
I don't see how a there are so many high break over angles, I have a 4" lift, 33's and a custom t-case skid that is only 7/8th of an inch below the frame (Dirty Fab Works) and I only have a 22.01 BOA.
Post by: Jeffy on August 01, 2007, 09:35:32 PM
All the high BOA's look to be form those running 35's and up.  Then you add in a belly-up's and you get numbers into the high 20's mod-30's.
Post by: Mozman68 on August 01, 2007, 09:42:35 PM
I probably screwed up my BOA...will have to measure when I get home from Chicago.
Post by: cmgorman94 on August 17, 2007, 07:12:00 AM
My RigRater Score:
432RRv1.0
Your Break-Over Angle (BOA) is 24.55 degrees!
Post by: Erik on August 17, 2007, 09:15:05 AM
My RigRater (http://"http://www.rigrater.com") Score: 794RRv1.0 with a BOA of 27.17
i think that's a bit strange considering if i had stock wheelsbase i would have a score of 29.61.... not to mention the addition of full width axles don't have any effect on score when clearly they offer a huge advantage both on and off road.
none the less, it's fun to see the numbers i suppose.
-Erik <--- classifies this just slightly more useless than an rti ramp :)
Post by: neale_rs on August 17, 2007, 01:29:00 PM
It makes sense, the longer the wheelbase, the lower the BOA.  The old flatfender CJ's can end up with very high BOAs due to the short 80 inch wheelbase.
Post by: Erik on August 17, 2007, 06:45:29 PM
so basically an unstable flattie having the wheelbase of a 4 wheeler with 44" tires would have a better rig rater score than a properly setup competition buggy?
makes sense.... i think i'll stick to my original thinking that building a rig to perform off road is a better idea than building a rig to compete in international web wheeling competitions, hehe
 :dance:
-Erik <--- can't wait to lower his RR score a couple points in order to get a wheelbase that's ideal offroad and horrible while web wheeling  :asshat:
Post by: cmgorman94 on August 17, 2007, 08:14:55 PM
 :dance:
Bwahahaha
That's the best comment I've read on here yet. I'm still laughing right now.  Good thing my Jeep still has the stock wheelbase so that I can wheel better than you on the internet.  The thing about that rig rater that also pisses me off is that it doesn't even take into account coils over leaf springs, etc.
Post by: chardrc on August 17, 2007, 09:04:16 PM
 :roflol: :roflol: :roflol: thats great.
Post by: Oilsmoke on August 18, 2007, 12:10:10 PM
So has anybody ever punched in a stock YJ vers A stock TJ?  Could be some fun WEB Wheeling
Post by: DodgeMudder on August 20, 2007, 03:47:36 PM
I punched in my 2" bl'ed Dakota sitting on 31" LTB's and got a better score then some posted even though I had a breakover angle of 10° or something like that, I ran it the other day and don't remember now, and don't care enough to run it again so it must take other stuff into consideration.
Post by: stickly on August 21, 2007, 12:12:43 PM
My RigRater (http://"http://www.rigrater.com") Score: 382RRv1.0 with a BOA of 17.64
Post by: dexetr30 on August 21, 2007, 06:19:22 PM
Anyone know what the stock height is on a TJ's transfer case skid plate? It's dark and raining and I don't feel like getting wet while trying to measure the thing.  :'(
Post by: dexetr30 on August 21, 2007, 06:38:44 PM
Ok, I went out and measured it and now I'm wet.
My RigRater (http://"http://www.rigrater.com") Score: 337RRv1.0 with a BOA of 14.69
(http://www.gothetahs.com/forum/images/smilies/2down.gif)
My measurement for my belly height was taken on an uneven driveway. Maybe I'll do better if I park it in my garage and take the measurement from the concrete floor.  :confused:
I'm sure my score will increase once I get the Rubi shocks and springs installed.
Post by: lutzke21 on September 06, 2007, 07:53:18 PM
OK, I'll play yer stoopid 'lil game...
504RRv1.0
Your Break-Over Angle (BOA) is 22.62 degrees!
Apparently everyones BOA is exciting and great requiring an exclamation point! javascript:void(0);
spam
