General Forums => The Mess Hall => Topic started by: rcherb on August 06, 2007, 02:19:57 PM
Title: New to 4Banger, already have a problem.
Post by: rcherb on August 06, 2007, 02:19:57 PM
Hey Guys,
I've got a 2000 2.5 wrangler, that is having stuttering problems, under power in 2nd and 4th gear, and also will idle strange almost to the point of cutting off after reversing or going slow in 1st gear, such as in a parking lot.  So far I've swapped the plugs to bosch fusions, which I'm taking back to exchange for chapion truck plugs, cleaned the dist cap, and wires, dielectic greased everything. Swapped the TPS, pulled the throttle body and cleaned it along with the IAC.  Any Ideas? :puzzled:
Title: Re: New to 4Banger, already have a problem.
Post by: neale_rs on August 06, 2007, 03:02:58 PM
Might want to try cleaning the injectors and checking the fuel pressure.
Post by: jfrabat on August 08, 2007, 09:17:28 AM
I used to have problems with mine with the Jeep loosing strength, and a change of the injectors and fuel pump (and fuel pressure regulator) fixed that.
