General Forums => The Mess Hall => Topic started by: floyd on February 11, 2008, 08:53:17 PM
Hi,Everyone. Anybody know if my 84 150-4 bellhousing that is currently mated to a T-5 will work with a AX-15?? Or better yet if I find a 91 150-4 bellhousing will it work with my T-5. I need the crank sensor mounting hole to update to efi. Thanks.
T-5, AX-5 and AX-15 aren't interchangeable. You would need a Dodge Dakota bell housing to be able to use a AX-15 on your AMC 2.5L.
There are kits to locate a CPS on the harmonic balancer.
For the 2.5L?
