General Forums => The Mess Hall => Topic started by: Jeffy on October 09, 2005, 07:15:30 PM
Vehicle Description
JEEP COLECTORS ! VERY RARE US POSTAL JEEP CJ WITH A CUMMINS 4B 3.9 LITER DIESEL ENGINE ! Back in the late 80's early 90's the US Postal service only had a limited few of thier Jeeps sent out and rebuilt with Cummins Diesels. They used the orignal frame and rear end. Installed a new fiberglass body, new engine and new TH350 transmission. This Jeep is fun to drive @ 40+ miles per gallon ! I have lowered the reserve to what you could part this Jeep out for ! So you can't get loose !
I have 4BT Cummins engines if your looking to repower your gas hog !
(http://i7.ebayimg.com/03/i/04/d3/15/f3_3.JPG)
(http://i12.ebayimg.com/04/i/04/d8/73/08_3.JPG)
(http://i7.ebayimg.com/02/i/04/d3/15/e6_3.JPG)
will someone buy it for me?
Here is a 4BT up for auction in KS, ends 6/10.
http://www.purplewaveauction.net/cgi-bin/mnlist.cgi?purple16/3155
Nice little engine. ALthough they are TALL. I wish they were easier to swap in CA. Diesel's aren't smogged yet.
what does the swap need? I want to go diesal when I am done with my gas. I think it would be great for wheeling if it is not a crazy swap.
Basically a complete drivetrain upgrade.
The engine only makes around 105hp but has something like 265lft-lbs. You can use a 4-speed GM transmission to it. Probably a 4L80e. Although a TH400 would also work. NV4500 will also work.
Then you'll need to upgrade the rear axle for sure. You will also want to upgrade the transfer case. A minimum would be a HD output shaft. A better option would be to use a 241, 205 or a Atlas/Stak. You'd also want to upgrade the front axle while you're at it. You could get away with the D30 but it would be your weakest point.
Oh and like I said, the engine is tall. You'll need a body lift and still might have to cut a hole in the hood.
there was a 93 yj on ebay at $15k a few days ago with that swap... professionally done and 50 state legal. very clean jeep... absolutely gorgeous
That's what started this thread. The auction was removed though.
guess he realized he wasn't going to get near half of the $50k he invested in the jeep....
i wish the pics were still there :(
It was okay...there is such a thing as TOO many mods...and that Cummins Jeep had too many.
Isn't there a real issue with the power to weight ratio with that engine in a Jeep?? It's real heavy, isn't it??
The 4BT weighs around 680-725 lbs dry. :shock:
