General Forums => The Mess Hall => Topic started by: jrollings on March 12, 2008, 06:27:48 AM
Title: 4.0l throttle body
Post by: jrollings on March 12, 2008, 06:27:48 AM
is the 4.0l throttel body a good upgrade or not really the reason being i can get one real cheap? thanks for the help
Title: Re: 4.0l throttle body
Post by: oldjeep on March 12, 2008, 06:56:10 AM
Seems to be.  I've got a bored out 2.5L throttle body on mine and it made a pretty noticable difference.
Post by: Jeep4banger97 on March 12, 2008, 07:28:07 AM
id say the 4.0L throttle body was a good and inexpensive upgrade for my jeep, pulls morea air and increased throttle response, personally i would do it for the cost its inexpensive!
Post by: jfrabat on March 12, 2008, 08:24:54 AM
Honestly speaking, I dont know if all by itself is that much of a difference, but combined with other things (injectors, good filter, etc.) I get a significant power increase in my rig (I specially notice it when driving down the highway; hills that used to require me dropping to 4th gear I can now overcome in 5th gear).  My advise: get it!
Post by: jrollings on March 12, 2008, 10:39:09 AM
thanks guys i already got the high flow intake and have the injectors just havent put them on yet
Post by: Bounty Hunter on March 13, 2008, 12:10:40 AM
I've got a 62mm throttle body that will fit your jeep, larger bore than the 4.0L TB (55mm) and it removes the taper below the throttle plate, which means lightning quick throttle response.  $85 plus a refundable core charge.  Shoot me a PM or email.  For anyone else interested, I should be getting in more '91-'04 TB's (62mm) real soon, just have one '91-'95 left right now.
Post by: jrollings on March 13, 2008, 05:24:51 AM
is there anything else id need to bolt it on or will this one bolt on with no problems ?
Post by: Bounty Hunter on March 13, 2008, 06:03:48 AM
Just use all your original sensors, including the IAS housing that's attached to the TB with 4 tamper-proof torx.
Post by: jfrabat on March 13, 2008, 08:24:26 AM
The process is VERY simple;
You are done!  This is probably the simplest mod to do to your Jeep...
Post by: Got Wood? on March 13, 2008, 09:17:38 AM
Just bring your jeep next wed. to jeep night and I will help you do the swap, just did mine last week and it was very simple.
Post by: jrollings on March 13, 2008, 10:27:45 AM
yea ill try and make it to jeep night wednesday but no guarantee
Post by: 95yjman on March 13, 2008, 11:52:03 AM
Is bounty hunter on Jeepininin also? That name sounds like I should know it.
Anyway, will the computer adjust to everything ok with the new TB?  Anybody every have any major problems with that when they did the swap?
Post by: jfrabat on March 13, 2008, 11:53:59 AM
Yes, but it takes a couple of minutes to "learn"...  Idle will be off when you first start it, but it will adjust automatically.  You can always disconnect the battery and have it "learn" from scratch.
Post by: Bounty Hunter on March 14, 2008, 03:06:56 PM
I'm not on jeepininin, but I do wheel in Indiana on occasion.  Usually Redbird and, to a lesser extent, the Badlands.
