General Forums => The Mess Hall => Topic started by: mack90 on April 05, 2008, 05:28:58 AM
Title: Gear Ratio
Post by: mack90 on April 05, 2008, 05:28:58 AM
I was planning on going with 4.88 gears in my 98 tj se, but wanted to upgrade the rear axle for a little more durability.  Low and behold, I came across front and rear Rubicon axles with lockers for $2900 - the front has chromoly shafts too!  Now I guess I'm throwing in a dana 44 front too.  My final plan is to go with 33" tires, nothing bigger.  I will still use this jeep on the highway too.  Now that 5.38 gears are an option, are they too much for highway driving with 33"?
TIA,
Mack
Title: Re: Gear Ratio
Post by: Mozman68 on April 05, 2008, 05:38:46 AM
If you are going 33", why not just go up to 35"???  You know you want to....
Post by: mack90 on April 05, 2008, 05:59:34 AM
33's are the magic number for me.  I would probably have gone 35's if I had a 6 cylinder.  I was actually hoping for better economy at the low speeds with this project.  My rubicon sucks gas when driving at idle speed.
Post by: Jeffy on April 05, 2008, 12:07:19 PM
TIA,
Mack
Are you going to be using the stock air lockers?  If you are then that will limit you to 5.13's.  5.38's are a bit low for 33's but would be fine for 35's.  5.13's would be good for 33's.
Post by: mack90 on April 06, 2008, 05:05:56 AM
What would the fuel economy be at 65-70 mph between the two?  RPM's?  There really isn't much of a difference between the two.
Post by: jfrabat on April 06, 2008, 06:59:24 AM
Anything over 55 mph and fuel economy goes down the drain regardless of axle; at that speed, it has to do more with aerodynamics!
Post by: mack90 on April 06, 2008, 10:32:30 AM
Will 4.88 gears turn over 33" tires when locked up at lower speeds?
Post by: aw12345 on April 06, 2008, 02:51:04 PM
Sure the 4 banger does better ofroad then on road power wise
Post by: jfrabat on April 06, 2008, 02:55:11 PM
4.88'S should be about the same as stock with 33's...  You should not have any problems.
Post by: bigchelis on April 07, 2008, 06:01:38 PM
I have 4:88's with 33x10.5x15 mud Super Swampers and a 4in superlift kit.
At 65mph my RPM are 2800
at 70mph my RPM are 3000
With a bone stock engine I got 16.8mpg
With a cold air intake and spacer and fuel magnet I get 17mpg
I was under the impresion that a cold air, spacer, fuel magnet would net me at least 2-4mpg, but I was wrong.
At least the engine bay looks nicer.
Post by: mack90 on April 08, 2008, 12:12:26 AM
I have a set of 33 12.5 swampers for offroad, and thinking about 33 10.5 bfg at's for the highway.  I think 4.88 will be best for the 33 10.5....may end up going that route.  Is that 17 mpg average or highway?
Thanks,
Mack
Post by: jcsanders79 on April 08, 2008, 08:43:12 AM
I have 33x10.50 BFG AT/KO's and 4.88 gears.  Its ok.  I have a 4:1 TC in the garage but its not in yet.  I am considering 5.38's so I can stay in  4high in the mud and use the 4:1 for crawling.  With the 4.88's I do alright on hills and mud but could use a little more torque and even with the stock TC 4Low is to low for hills and mud.  I am thinking the small differnce in 4.88 and 5.38 will help.  On road I'll be fine but this is a toy not daily driver.
Did you get those axles of the rubicon site?  I looked at them but only needed a front.  Also I don't think you can put 5.38 or even 4.88 on rubicon ARB's.  Aren't they thicker, is 4.10 the max?
Post by: Jeffy on April 08, 2008, 09:27:43 AM
If you take out the lockers you'll be able to run whatever gears that are available for a D44 in them.  The only thing stopping it now is that they use a 3.55 and under carrier.  This requires thick gears OR a shim to be made.  Currently you can get 5.13:1 in thick though.
Post by: mack90 on April 08, 2008, 09:30:47 AM
You can do 4.88 or 5.13 with the rubicon axles with stock locker.  I actually only wanted the rear axle.  I'm willing to talk if you want the front.  The front has new alloy axles and in great shape from what I can tell from the pics.  I would expect more than half the cost I paid for the front because they go for more....also alloy shafts  The price on the rubicon forum was without the alloy shafts for the front.....
Post by: bigchelis on April 08, 2008, 09:57:42 AM
My 17mpg is average.  I live in the bay area, ca and traffic is bad going 101 northbound.  On weekends when I do not have traffic I try to stay around 70mph.  It is an overall average stop and go/some freeway.
When I drive strickly on freeways(weekend trip), I get the same mileage.  I drive 80mph, and harder in the streets:its fun time.   Yet the same 16.8mpg
Post by: mack90 on April 08, 2008, 10:50:23 AM
I could live with 17mpg average!  What is your mileage for just in town?  I suspect it may be better than that.
Post by: jcsanders79 on April 08, 2008, 02:21:16 PM
Thanks but I have already started my project.  I don't want ARB either.
