General Forums => The Mess Hall => Topic started by: jrollings on April 08, 2008, 06:03:48 AM
sometimes when i go to turn it feels as if the power steering assist is gone, my fluild level is okay, it doesnt feel as if the p/s is gone all the way but occassionally has more resistance while turning and the steering wheel doesnt always come back after a turn. the steering wheel feels sloppy as well almost like the pitman arm is shot but the connection b/w the steering gear and pitman arm is tight any ideas ??
Have you checked that your belt is tight enough?
yea sry i forgot to mention that the belt is tight
Push your trnasfer case handle down really hard to make sure you are fully in 2-high...or shift into 4-high and then back into 2-high.
When my pump went out it did a simular thing the months prior.
