General Forums => The Mess Hall => Topic started by: Jeffy on October 16, 2005, 07:55:38 PM
Just curious on the new 231 FAQ I did.
http://www.4bangerjp.com/forums/viewtopic.php?t=447
I'm sure there is something I'm missing.
Mention that the 2LO conversion also gives a true Neutral setting on the older cases and it looks pretty good.
Very interesting....written even so a moron like me can understand it!!
This was a bit confusing, though, is it a typo?
With Wranglers, pre-'97's require a long gear while Post-'95 requires a short gear.
That was in the speedo gear section. Shouldn't it read "pre-95's require a long gear and post-'97's require a short gear"?
You mention the SYE upgrade, but what about all the differences in the stock outputs over the years? Many times jeepers are looking for an OEM replacement and don't know what years will fit.
I don't think the speedo gears changed between '95 and '97, the long style was much older.
Thing about 1995's and more specifically 1995.5's is that they started using TJ parts on them. So they tend to be a mixed bag.
If you want to get picky, the shaft for rails are longer on the older Jeeps, too.
I decided to leave out referance to lengths of the output shaft since it's not as important.
