General Forums => The Mess Hall => Topic started by: BOOGIE444 on April 22, 2008, 01:12:12 PM
The oem one that attaches to your frame, or the other after market one which I am not sure where it is supposed to be attached too.
[attachment deleted by admin]
The top one. The bottom ones are kind of hard to get a strap on since they are so small.
I agree, I like the top ones. Not only will it hold a strap better but you'll also know when it's overloaded since they will straighten out a bit before they break.
Thanks guys...
I also just pulled the trigger on some cheap oem style front tow hooks, are those also going to be too small to get a strap on them?
Thanks guys...
The TJ ones are kind of small, but I don't really know of any good aftermarket alternatives - other than a good bumper with d-rings
I just attached the front style hooks to the frame in the rear....
(http://i68.photobucket.com/albums/i33/jlafaive/DSC00969.jpg)
That location always scares me, mostly because that is the section of a YJ frame that most frequently becomes dust.
He might want to check with any 4x4 store with a shop. THey are typically removed from Chevy's and Fords when they add a lift. They might just give you some.
If you're going to go the bumper route, you can just get a bumper with a 2" hitch. Hitch point make good tow points since you can lock the strap into the high with the pin.
