General Forums => The Mess Hall => Topic started by: wuze on June 06, 2008, 12:13:04 PM
Title: beadlock
Post by: wuze on June 06, 2008, 12:13:04 PM
i think for beadlock wheels in 8x16 for my 97 tj with 6" flares.
what brand and where in florida can i get the wheels.
i have bought last week in west palm beach a tj that is actually in my friends yard , before i ship
the jeep to europe i will put some good things on :naughty:
Title: Re: beadlock
Post by: oldjeep on June 06, 2008, 12:22:56 PM
Walker Evans, Poison Spyder, KMC  all make nice beadlocks.  If you are not planning on running it on the street, there are plenty of weld on options for steel wheels.
Title: Re: beadlock
Post by: Mozman68 on June 07, 2008, 06:31:40 AM
I'm going to try the Staun internal system when I have some money....but I do like the Walker Evans wheels.
Title: Re: beadlock
Post by: aw12345 on June 07, 2008, 06:48:31 AM
Love the poison spider bead locks. Basset makes very affordable beadlock wheels.
Chuck you been troubleld much by the winds and floods out in Minnesota?
Title: Re: beadlock
Post by: oldjeep on June 07, 2008, 10:28:43 AM
Weather has been crappy with some hail, but no flooding anywhere near where I live.   It has really put a crimp in the waterskiing though ;)  This mornign was my first time out this year and the water is still pretty cold.
Title: Re: beadlock
Post by: Jeffy on June 07, 2008, 01:45:19 PM
I like the Hutchinson Beadlock since it traps the bead on both the inner and outer rim.  They are a 3 piece wheel system, kinda like the HMMWV wheels.  They are DOT legal as well but that's probably not going to be an issue for you unless they have similar laws in Europe.
Title: Re: beadlock
Post by: oldjeep on June 07, 2008, 02:39:23 PM
They make an excellent wheel if you can spend the $$$$$.  I ran recentered Humvee rims on my CJ and like the safety of that design.
Title: Re: beadlock
Post by: Jeffy on June 07, 2008, 05:02:14 PM
I agree they are $$$$ BUT they are really nicely designed. HMMWV wheels aren't bad either.
Title: Re: beadlock
Post by: Jesse-James on June 07, 2008, 07:42:43 PM
Why is that? If you weld the rings to a DOT wheel it is legal on the street far as I know.
Title: Re: beadlock
Post by: oldjeep on June 07, 2008, 09:31:30 PM
I don't care about DOT legal, the problem is the mechanics of how that type of beadlock works.  Many folks run them on the road, there is no way I would.
Title: Re: beadlock
Post by: Jeffy on June 08, 2008, 01:15:26 AM
That doesn't make them DOT legal.
Title: Re: beadlock
Post by: wuze on June 08, 2008, 03:45:11 AM
i will use them only for competition :naughty:
the law here is so stupid i cant run legal a wheel from a xj or a zj on a tj :brick:
it cost me a lot of money to get my tj streetlegal (ok not 100% streetlegal but close) ;)
 :wave:
Title: Re: beadlock
Post by: Jesse-James on June 08, 2008, 11:53:52 AM
I assume you've read this......
Beadlock discussion on Pirate4x4 (http://www.pirate4x4.com/forum/showthread.php?t=363606)
Title: Re: beadlock
Post by: Jeffy on June 08, 2008, 06:30:35 PM
Still doesn't mean they're DOT approved.  It's like buying a car, modifying it and then trying to get warranty work done.  Technically they should fix it but they won't.  DOT does not need to be stapped on the item in question BUT you can still get ticketed for it.  Then you can take it to court and fight it.  That's more time and money lost.
The other thing that no one seems to have gotten is that if the vehicle is approved for sales in the US, anything on it trumps state laws.  So if someone was to get beadlocks on their vehicle they would be legal in all 50 states.  Things like flares, lift and such apply.  This is a weird law since some states limit the height of bodylifts and flare widths.  I know Hawaii limits body lifts to 2", IIRC.  Weird thing is if you add a 1" body lift, it's considered 2" because it uses the stock 1" mount.  It makes no sense at all but that's the way it's done.
Title: Re: beadlock
Post by: Jesse-James on June 08, 2008, 07:41:17 PM
^ That is odd. ^
Is there some safety reason why you shouldn't run them on the street? It's something I am planning for and don't like the price of the Staun internals.
Title: Re: beadlock
Post by: oldjeep on June 08, 2008, 08:23:42 PM
^ That is odd. ^
Think about it for a second.  32 tiny bolts mounted in single shear and torqued to only around 20 ft lbs.  There is absolutely nothing supporting the bead.  It doesn't take much to get those bolts moving up and down a tiny amount.  Not something I would trust my life to on the highway.
Title: Re: beadlock
Post by: Jeffy on June 08, 2008, 08:36:52 PM
^ That is odd. ^
It's not unheard of to shear the heads off a ring bolt.  Once one goes, the rest seem to go like popcorn.  The ring is the only thing holding the outer bead to the wheel.  Once that goes, the tire comes off the wheel.  On a trail, it's not too big of a deal but if you're running at higher speeds, it could be catastrophic.  Checking the bolts periodically, would be a good idea on a daily driver.  More maintenance then standard wheels or three piece wheels like the Hutchinson.
Oh another reason why most beadlocks aren't DOT approved is for liability.  Kinda like how bumper companies say they're for 'looks only', they're protecting themselves.
Title: Re: beadlock
Post by: Jesse-James on June 08, 2008, 08:50:44 PM
I'll have to do some thinkin'. Maybe I'll have to fork for the internals.
