General Forums => The Mess Hall => Topic started by: 6099 on October 26, 2005, 11:09:08 PM
Title: Electric Fan
Post by: 6099 on October 26, 2005, 11:09:08 PM
Hi, I'm new to the forum. Have a question. I have an electric fan (presumably for the A/C) which plugs into the factory wire loom. But in the 5 years I've had the jeep, never seen or heard it operate.
(A/C and engine temp is normal)
Assuming the fan motor still runs, would it be safe to cut it off the factory loom and and hook it up to the battery with a switch in-cab?
This would be a great backup incase the engine mounted fan kaputs on me.
Any other better ideas what I shud do? thx.
Title: Electric Fan
Post by: Bounty Hunter on October 29, 2005, 02:51:41 PM
Is this on an XJ?  They're designed to kick on when the engine reaches a preset temp, or when the AC compressor engages.
Title: Electric Fan
Post by: 6099 on November 06, 2005, 10:18:01 PM
YJ. The fan never turns on.
Title: Electric Fan
Post by: Bounty Hunter on November 06, 2005, 11:41:00 PM
Never seen one from the factory on a '95 YJ, must be an export thing.
Doesn't sound like you'll have any trouble hooking it up as you plan, as long as it's not your only fan.
Title: Electric Fan
Post by: Jeffy on November 06, 2005, 11:53:29 PM
YJ's never came with electric fans from the factory, so where did it come from?
Title: Electric Fan
Post by: 6099 on November 07, 2005, 08:25:17 PM
Yah, I guess its an export thing cause the electric fan wires are plugged into the headlight wire loom. thanks all.
