		General Forums => The Mess Hall => Topic started by: neale_rs on June 27, 2008, 08:00:48 AM
				 I'm considering getting a Tera 4:1 with 21 spline input to match the AX5 but have a long term plan to swap in an SM420, at which point I would like to have the 23 spline input.  Does anyone know if the Tera 4:1 input can be changed like on the regular NP231?
 Thanks
				All that is being changed is the planetary gear set for the lower reduction. It would seem to me that you could. I have no experience with this though...
 I'd agree BUT you never know.  Call Tera and see what they say.  I know with something like the Atlas, they want you to ship it back to them.
				i don't know for sure if you can change the input. in my head somewhere it is saying yes.  but, i've been wrong many times before.  i do know that you will love the tera low it's the greatest wheeling with a really low and slow gearing.   :weee:
				Thanks for the comments.  I'll contact Teraflex and then post what they say.
				A friend of mine is doing the same thing, Tera will insist you ship the 231 to them to swap inputs.  It's worth the money, then they'll continue to cover it with their great warranty.
 Will they even warranty it in Mexico though?  Shipping it back and forth would be $$$.
 Here is what they said:
 "Yes you can swap out the 21 spline input for a 23 spline. It
 requires timing the planetary gears before you reinstall the input. If your
 not comfortable trying that kind of swap you can send the planetary to us
 and we can install the input."
 Being in Mexico does complicate things, the hardest part is getting it back into Mexico without a new receipt.  I could get the warranty by having the unit shipped to and from a US address and handle the import export myself.  Amazingly it is often cheaper to buy from local shops, it seems they get dealer discounts and can often deliver in Mexico for the same price as in the catalog without any additional shipping or importation costs incurred by the buyer.
 Thanks
 i do the swap of my ax5 for the sm420 at this time and i change the 231 inputshaft for 23 splines :naughty:
 and i hope this will work but its not so easy :confused:
 (http://up.picr.de/1124514.jpg)
 this is what eric from novak has send to me :clap:
 (http://up.picr.de/1124515.jpg)
 (http://up.picr.de/1124516.jpg)
 hope this will work, i have only problems with the 23 splines inputshaft :puzzled:
 :wave:
				Please let us know how it goes with the swap.  Thats pretty much what I would like to do some day.
 What kind of problem - don't know how to change it, or it's not fitting?
				find the right one is the problem :mad:
 i think out of a 95 or newer xj 4L should fit, i try to find one
 :wave:
				IIRC there are 5 different input shafts.  Novak has a nice writeup on it.  http://www.novak-adapt.com/knowledge/np_nvg_input_gears.htm
 Probably should have ordered one from Novak when you got the transmission.  Nice choice by the way!   :thumbsup:
 i have ordert my sm420 with 21 splines output but got 23 splines ???
 and now i want to go with 23 :naughty:
 my problem is that i dont live around the corner  :brick:
 :wave:
				(http://up.picr.de/1125903.jpg)
 (http://up.picr.de/1125904.jpg)
 (http://up.picr.de/1125905.jpg)
 got this from a friend, someone know if this fit :puzzled:
 i will ask tomorrow eric from novak :biggrin:
 :wave:
				I beleive most of the ones that are used for conversions are the ones from an AX-15, which are the short 23 spline shafts.
				eric from novak said that this is the right inputshaft :clap:
 should i open a new thread when i give you infos about the swap :puzzled:
 :wave:
				Either that or just just with it here.
				so, the swap is done and i love my low gearing :clap: :clap:
 (http://up.picr.de/1151709.jpg)
 here you see the new hole for the shifter
 (http://up.picr.de/1151712.jpg)
 (http://up.picr.de/1151713.jpg)
 (http://up.picr.de/1151714.jpg)
 (http://up.picr.de/1151715.jpg)
 i had to mod. the bellhousing for the starter :mad:
 and the best i can keep the belly up  :clap:
 all over it was an easy swap, thanks to eric from novak :thumb:
 :wave:
				Wow, that's a nasty looking hack for the starter.  Have you contacted Novak to see what's up?
				I hope you are planning on cleaning up those cuts.  Having a bunch of sharp notches like that is just asking for cracks.
 Is that a conversion bellhousing, or just a stock piece off something?
				I think you ignored this part of the directions:
 This kit requires the use of a new, gear reduction starter like the Mean Green #3212  (typ. cost $250)
 i have to drive this weekend, a lokal competition :naughty:
 next week i finish and make it looks good  ::)
 :wave:
 :wave:
 You have already done a lot of structural damage to it.  I'd make sure that there is no way that you can smack it on a rock now.
				next week a friend of me will weld a plate over the hole and then  its ok again :hump:
 i know its not so good but the mistake was on ericīs side, and no time to order the correct one :mad:
 :wave:
 :wave:
 What mistake did eric make?  Looks like you tried to use a stock starter on a kit that requires a reduction starter?
 i told him that i need all the parts for the swap because here in austria is no chance to get missing parts :nono:
 we pay here for a stock starter 700-750$ and if you find a company who sells this mr. green you have to wait 3-4 weeks and then you pay so much that you kill the salesman :brick:
 this was the only option for me!
 i live not in the states, for me here its not so easy :'(
 :wave:
				Well good luck in your competition with the granny gear and the terra low your Jeep should really crawl at a snails pace. Once you fix the bellhousing and maybe weld an extension on the belly up fior the trans it will look nice and work like a champ
 thanks :beers:
 :wave:
				Thanks for sharing your experience with this project.  How did it go at the competition?
