General Forums => The Mess Hall => Topic started by: Bill M. on July 09, 2008, 09:17:58 PM
So I found a Ramsey Winch, 8000lb , for $300 dollars. It works, and isn't beat to hell, so now I need your advice.... is Ramsey a good brand????
What model is it? REP8000? $300 isn't too bad actually. I've seen them for around $350 used. They are OK winches but you have to take some things into consideration. The REP8000 is an older winch. It uses a permanent magnet instead of the stronger electro magnets that the higher end winches use. This allows the winch to use less amps when under a load.
In any case it's a decent entry level winch.
i have a ramsey rep 8000. it's an oldie but works good and is reliable. it's not the fastest but it works fine for the limited amount that i use it.
