		General Forums => The Mess Hall => Topic started by: willbacker45 on August 09, 2008, 11:02:55 PM
				so i just installed a 2in BB on the jeep but the front is sagging about 3/4 of an inch and barely looks like i added anything to it, but the back seems up real high...so if i bought a 3/4 in spacer could i stack it on the 2in spacer to level the front?
				yes but if you installed a 2 inch puck on each spring shouldn't it raise each side 2 inches and not just the back?  you might want to check and make sure you installed it correctly or something.
				A spare set of front coil isolators would work well to level out the front, they are stackable with the 2" spacers.
 I had to add them when I put a 2" BB on my brother-in-laws 4banger TJ.  Worked great to level the ride.
 so would i just use two isolators and then the spacers?
				i just saw that mopar sells half in. spring isolators should i get those
