		General Forums => The Mess Hall => Topic started by: crtjse on August 11, 2008, 10:38:35 AM
				I am planning on getting a 2.25" BB with 32X11.15 BFG AT's on pro comp series 97 15x8's on my 04 TJ SE. I was wondering whats the maximum backspacing i could get without any rubbing? I was planning on going with 3.75, but from what ive heard, the wheels would stick out too far and look bad.
 I'd go with something in the 4.75"-4.25" range.  You may still need to shim the steering stops but you won't miss the difference. 3.75" is the norm for those running 35's and up.
				what do you mean by shim the steering stops?
 The steering stops are what set your steering limits.
				Gotcha, but what do you mean by shimming them?
 Adding shims/washers to adjust the stops.  http://4bangerjp.com/forums/index.php?topic=2697.0
				Thanks so much for your help, I think I'm going with 4.25"
