General Forums => The Mess Hall => Topic started by: mooress on October 07, 2008, 12:57:07 PM
Title: Wipers don't park when turned off
Post by: mooress on October 07, 2008, 12:57:07 PM
Quick question.  I failed my PA state inspection a few days ago because my windshield wipers don't "park" when they're shut off.  Meaning that they don't go back to the "rest" position.  Mine just stop wherever they are when I turn them off.  My question is this.  On an 87 YJ, are they supposed to go to the rest position, or do I have a problem?  Just trying to figure out if this is how the wipers functioned from day1, or if there is a malfunction.
Thanks,.......sm
Title: Re: Wipers don't park when turned off
Post by: neale_rs on October 07, 2008, 01:03:02 PM
They don't park on my '95 either.  I always thought it was normal for the YJ.
Post by: oldjeep on October 07, 2008, 01:42:49 PM
My 94 doesn't park either.  Always have to jog them
Post by: aw12345 on October 07, 2008, 02:22:37 PM
There should be a park ppsition switch on the wiper motor that gets direct ignition voltage when ever the key is on. Either no power to this switch or the switch failed or is stuck open
Post by: Jeffy on October 07, 2008, 03:02:14 PM
Something must be wrong with the switch.  My '92 parks fine.  Actually every YJ should park.  If you drop the windshield, to gain access to the wiper motor, you should see that it uses 3 wires.  IIRC, two are hot one is ground.  One of the hot will run the wipers normally.  The second hot will run them one cycle then park.
Post by: chardrc on October 07, 2008, 05:05:55 PM
my 90 yj doesn't park either.. will maybe eventualy look into this..
Post by: Jesse-James on October 07, 2008, 09:59:01 PM
My 95 parks fine too. Must be a common problem that I don't have.......yet.
Post by: Oilsmoke on October 09, 2008, 07:51:59 PM
My motor is gettin slow but it parks still.
Post by: 95yjman on October 09, 2008, 09:15:52 PM
My 95's wipers park...so far.
Post by: jfrabat on October 10, 2008, 02:55:36 PM
Try lubing the joints; mine were doing the same, and I did not lube the joints until AFTER the ball-joint on the motor tore off.  Lubing it will save you from having to weld the thing back up!
Post by: countryboy514 on October 15, 2008, 08:03:08 PM
my 97TJ does the same thing. its a park switch inside the wiper motor. you have to replace the whole thing
