General Forums => The Mess Hall => Topic started by: jcd1026 on December 03, 2008, 11:23:59 AM
Title: Any ideas on where to start?
Post by: jcd1026 on December 03, 2008, 11:23:59 AM
Ok. I've got a 95 yj with the four cylinder. I've recently started having problems with driveability. When I crank it cold, I get a hard lope, as it warms up, the lope goes away. After warmup, it stumbles when under 1500 rpm, whether in gear or not. After about 15-20 minutes of steady driving, the stumbling stops and the check engine light comes on. When I turn it off and back on, the light goes off, but drivability returns for about another 15 mins and then the light comes on again.
Now for the codes: 12, 21, 33, 47, 51 & 52.
12 is battery input was disconnected within last 50 key cycles.- I haven't disconnected the battery in at least 6 months, it is also a daily driver.
21 is a variety of oxygen sensor problems. - I changed it out about 2 months ago.
33 is a broken or short in duty cycle purge solenoid circuit - anybody know what this is?
47 is Battery voltage sense input below target charging during engine operation. Also, no significant change detected in battery voltage during active test of generator output circuit - any clues on what this is?
51 is A lean air/fuel mixture has been indicated by an abnormally rich correction factor.
52 is A rich air/fuel mixture has been indicated by an abnormally rich correction factor.
rich and lean conditions detected? does anyone have an idea?
Thanks
Title: Re: Any ideas on where to start?
Post by: neale_rs on December 03, 2008, 11:40:54 AM
Sounds like you need to check the charging system and the oxygen sensor.  One of my rules is always to check the last thing that was "fixed".
Good luck
Post by: jcd1026 on December 03, 2008, 11:58:46 AM
is it possible that the oxygen sensor would go bad in 2 months?
Post by: neale_rs on December 03, 2008, 12:36:31 PM
In general anything can go bad at any time.  A lot of my Jeep problems stem from bad installations, wrong parts, etc. either by my own doing or bad mechanics.
