General Forums => The Mess Hall => Topic started by: jfrabat on February 10, 2009, 09:28:09 AM
Title: Matching Paint for the Jeep
Post by: jfrabat on February 10, 2009, 09:28:09 AM
Hey, guys, where would I find the paint code for my Jeep, and where could I buy matchingpaint for some touch ups?  My paint is peeling in some places (my Jeep has some cheap paint job that is now peeling; God only knows what the PO did to it!), and I want to touch it up to avoid rust (I really dont care if it does not look perfect; good enough is fine as long as it does not stick out like a sore thumb and prevents rusting).
Title: Re: Matching Paint for the Jeep
Post by: Jeffy on February 10, 2009, 11:56:16 AM
You want to look for the ID tag on the firewall behind the brake boster.  IIRC, it's a 4 digit code.  Usually 2 letters followed by two numbers.
Also, keep in mind that unless they are able to take samples and of the Jeeps actual paint, it probably won't match 100%.  Most automotive paint shops can mix you a small batch and then get it to the prefect tone.
Post by: dexetr30 on February 10, 2009, 05:22:09 PM
This link should give you everything you need as far as where the paint code is located.
http://www.automotivetouchup.com/paint-codes/jeep.htm (http://www.automotivetouchup.com/paint-codes/jeep.htm)
You can also buy your paint from them.
Post by: jfrabat on February 12, 2009, 01:06:16 PM
So what would be my paint code?  PG5?  There is not PNT code prior to any other code, so it is not like the site...
(http://i46.photobucket.com/albums/f138/jfrabat/Jeep/DSC09842.jpg)
Post by: Jeffy on February 12, 2009, 03:34:14 PM
Yes, PG5 is for Hunter Green Metallic.
Which could also be found; http://4bangerjp.com/forums/index.php?topic=438
Post by: jfrabat on February 12, 2009, 04:14:19 PM
That's what I thought; just wanted to confirm before I ordered, as neither NAPA nor Advancd Autoparts has that color in stock...  Thanks!
Post by: dexetr30 on February 13, 2009, 08:56:42 AM
Yup pg5. It's the 6th one from the bottom in the link.
http://www.automotivetouchup.com/choosecolor/choosecolor.aspx?year=1994&make=Jeep&model=Wrangler (http://www.automotivetouchup.com/choosecolor/choosecolor.aspx?year=1994&make=Jeep&model=Wrangler)
