General Forums => The Mess Hall => Topic started by: DiGGeR77 on March 13, 2009, 09:20:50 AM
Title: Wiring up a winch
Post by: DiGGeR77 on March 13, 2009, 09:20:50 AM
I was at my local Sams Club and found a deal I just couldn't pass up, a Champion 10,000lb winch w/ acc package for $350.00, I did do alot of research and found alot of possitive reviews as well as negative.  For an Extra $30 I got the 3yrs Sams club exchange (bring it back for exchange for a new one). So If nothing else, it breaks down to $10 bucks a month for the next 3 yrs of having a huge winch. It comes with a package to let you mount it to the front and back by way of a receiver (I'll post pic's of my build...later) But now getting down to the real meat of things....
How are you suppose to wire it up correctly? I have to sets of no#2 wire(one set for the front and one for the back) to connect to my battery. I really dont want to hook it directly to my battery terminal, do to the severe weight and bulk that it would cause not to mention it would look like Hell. I was thinking of a juction box, but before I burn too many brain cells trying to re-invent the wheel, I thought of asking you guys how you did yours.
Title: Re: Wiring up a winch
Post by: FourbangerYJ on March 13, 2009, 10:26:06 AM
http://www.warn.com/truck/accessories/quick_connect_all.shtml
This kit is made to have your winch on the front or rear. My suggestion is to leave it on the front, keep the extra set of wires in the Jeep incase you need to move it to the rear. Once your done move it back to the front.
Post by: oldjeep on March 13, 2009, 12:52:01 PM
Just be aware that if you decide to carry that winch inside the jeep that you better figure out a solid way to secure it.  It'll be a 100 lb chunk of death if it's just sitting in the back of the jeep when you roll over.
Post by: DiGGeR77 on March 13, 2009, 02:12:20 PM
Its home is going to be in the front and will always remain in the front until I get in a sitution where i can't go foward, and the kit already came with an 2nd set of wires to run to the back, I just need to know if theres a clean way of hooking these up to the battery.
This may be a stupid question but, the winch covers about 60%-70% of the radiator does this cause the jeep to run hotter? (I'll post pics this weekend)
Post by: jcsanders79 on March 13, 2009, 02:16:16 PM
Most will have an in line fuse of some type and they are safe to hook directly to the battery.  Why don't you want to hook it directly to the battery?  My winch covers some of the radiator but not 60-70% so I have no idea how thats going to work out.
Post by: Jeffy on March 13, 2009, 02:58:01 PM
Hmm, my Warn does not have any fuses.
Post by: oldjeep on March 13, 2009, 03:05:25 PM
Winches do not have fuses.  Just hook direct to the battery, might be a good time to switch to marine style battery connectors, makes it easier to connect multiple cables.
Post by: neale_rs on March 13, 2009, 03:29:08 PM
You might consider these:
http://www.premierpowerwelder.com/terminals/terminals.html
Post by: aw12345 on March 13, 2009, 03:34:54 PM
Look on some tow trucks and some emergency vehicles they have a quick disconnect for the battery jumper cables
You should be able to get those at a welding supply store
Post by: Jeffy on March 13, 2009, 04:22:47 PM
I'd imagine the amp load when pulling full weight would blow a standard fuse. There really isn't much in a winch to go wrong either.  The motor, two relays and some wiring, they're pretty robust.
You can get them at NAPA Auto parts as well.  Usually $20.
(http://www.winchking.com/images/new%20001.jpg)
Post by: rubberducky on March 14, 2009, 07:44:24 PM
Yea I saw that winch also, I almost bought it, but I'm not sure how the squirrels would push a warn winch on the front as well as the Champion on the  back. (always have wanted to winch my jeep into a tree like in The Gods Must be Crazy) If I'm not mistaken it comes with a quick disconnect just like my warn 9.5TI in the cradle does. Mine is hooked to battery and is fine, You kinda need to hook it up directly because of the amount of power it draws. Or you would be popping fuses all day. Besides I'm not sure how much you drive but me personally I strip my jeep most of the time to save weight. Which does help for MPG's. No backseat, winch, hardtop, spare tire.  Yea I know, I have 100k on it and the squirrels are getting tired.
   RD
Post by: jcsanders79 on March 14, 2009, 08:56:13 PM
Maybe its not a fuse but there is a hard platic piece on the red wire, 9.5ti?  Maybey its a disconect like mentioned?
Post by: Jeffy on March 14, 2009, 09:30:25 PM
Have any pictures?
(http://image.fourwheeler.com/f/9244453/129_0605_10_z+project_nissan_titan+winch.jpg)
Post by: GTChrisB on March 14, 2009, 10:00:06 PM
Just be careful with this mofo.  Got one in Jan and have burned 2 alternators as a result of it.
I wired it directly to the battery.  However, I take mine off when it's not going to be used.  It either sits in the Liberty or the living room next to the door.  Have to cover it with an old Army foul weather coat because my wife's rabbit likes to chew electrical wires if not watched.
Post by: jcsanders79 on March 15, 2009, 02:30:41 PM
Have any pictures?
Nope and don't care enough to go take one or look to make sure I'm remembering it right.  Either way its still wired straight to the battery.
Post by: rubberducky on March 15, 2009, 02:44:06 PM
Yea Its pretty ruff, I lost a battery back when IKE showed us a visit. I went around winching trees, fences, cars. My sister is a doctor with some wealthy friends, they paid me to move stuff. I broke the cable twice, and a lost the battery. I turned the two 1-2ft sections of broken cable into two snatch blocks, bought a battery and was still ahead $300. I don't  have a pick, but its the same as that 10,0000 champion. similar cradle, and then the quick disconnect wire like posted. I found mine has no effect on the cooling of the jeep, even under a heavy load on a long trip. I ran my wires from battery between the fuse box and the lip against the hood to behind the passenger headlight under the grill. zip tied to the sway bar to the drivers side. (where the female or male end of connector is.) I also zip tied the other connector to the cradle to ensure it won't get caught on anything. If you were going to run a set of cables to the back I might suggest running them inside the frame. (I drive through the woods ALOT) that way the wires don't get ripped off, and short out. The only issue with the connectors I've found, is if you leave the winch at home for a while the connectors will oxidize. My winch sometimes does not have enough power to flip the solenoids. I can take pictures of my winch if ya want, but it would have to be with my phone. my camera is at home.
