General Forums => The Mess Hall => Topic started by: melbill on June 05, 2009, 03:20:10 PM
Title: trying to keep low center of gravity
Post by: melbill on June 05, 2009, 03:20:10 PM
I have a 95 YJ. I want to fit 33s as it is my daily driver. I want to keep my center of gravity low as most of my off roading is trails, mud, and fire roads. No real rocks here. I was thinking of a 2.5 inch OME or RE lift and xenon flat panel flares. Does this sound like a workable combination? I have read good reviews of both lift kits on this site; has anyone used both and have a good comparison. Also I am looking at the 4 inch xenon flares. Should I use the TJ or YJ flares to get the most clearance?
I appreciate any direction or advice I can get.  Even if it is to go a different direction.
Title: Re: trying to keep low center of gravity
Post by: neale_rs on June 05, 2009, 04:59:17 PM
It should work with the TJ flares and some sheetmetal cutting to match the flares' openings.
Post by: jfrabat on June 05, 2009, 05:18:20 PM
with a 2.5" lift and some sheet metal cutting, you shoul dbe able to clear 33" tire, which should be enough for firetrails and trails...
Post by: Jeffy on June 05, 2009, 06:06:23 PM
OME's lift is one of the best.  The 2.5" will clear 32's easily and 33's with some trimming.  I would go with TJ flares.  Personally I'd go with the Rubicon's flares since they are fairly inexpensive and allow you to cut a lot out of the fenders.
Post by: drunkencityworker on June 13, 2009, 11:03:17 PM
I have tube fenders in front and tj flares in back. 4 inches of sua and even though I have 305/70(metric 33s) I could easily go 35s just cant afford regear at this time.
Post by: jfrabat on June 14, 2009, 09:56:43 AM
Someone here (dont remeber who; was it Moz?) posted a pi of someone on their club that runs 35" tires with no lift (just trimming) on a TJ...  So 33 is most defenetly possible witha 2.5" lift if you trim enough.
Post by: rubberducky on June 17, 2009, 11:37:45 AM
05 tj with 2'' lift. well I think its more of a 1 3/4 and I have 33-12.5 with a set of spacers on factory steelys with no cutting. No rub. Its my DD also. They will rub with some articulation.
