General Forums => The Mess Hall => Topic started by: chkustom on June 10, 2009, 07:26:28 PM
Title: waggy 44's
Post by: chkustom on June 10, 2009, 07:26:28 PM
Hey guys, Are any of you running a front dana 44 out of a waggy. What is width compared to d30.
Title: Re: waggy 44's
Post by: Bounty Hunter on June 10, 2009, 09:28:00 PM
I'm running one, and they are the same width as the D30.  Just watch out for the full-size Wagoneers labeled 'Cherokee' or 'Chief' as they may have the widetrack axles, 4" or 5" wider than the d30 axle.
Post by: chkustom on June 11, 2009, 04:33:16 AM
Bounty Hunter , are you running it soa. I noticed that the left spring perch is cast into the housing. If so do you have any pics. Do you happen to know what gear ratio came in the grand waggoner.
Post by: Bounty Hunter on June 11, 2009, 04:04:48 PM
Yes, I'm running SOA, and many Waggy's have 2.72 gear ratio or similar tall ratio.
Post by: Bounty Hunter on June 12, 2009, 10:41:25 AM
I used factory Mopar spring pads and ground the inboard side down so it rests on the cast area closest to the diff, then the outboard side rests on the axletube and the spring pad sits level.  I then welded the spring pad to the tube using standard rod and to the cast areas using 55%nickel rod.
I had to do some grinding on the bottom of the axle for the inboard ubolt to fit snugly to the bottom of the axle.  It rests on the old cast spring pad and you need to take the square edge off of it.
I'm currently having a Ford HP44 housing narrowed to Waggy width to run the Waggy axleshafts and have the advantage of a high pinion.
(http://sija.org/bounty/jeepmods/SL740323.JPG)
Post by: chkustom on June 12, 2009, 06:45:13 PM
Thank's for the pic's.
