General Forums => The Mess Hall => Topic started by: tjjohn on June 29, 2009, 02:52:13 PM
can or how can i adjust the timing on my 1998 2.5
You can't.
Well, you can by modifying your CPS. This will give you a few degrees, tops. Distributor should be keyed to go in 0* or 180* so you can adjust the timing the normal way.
Jeffy,
Could you explain how it works please and how's the camshaft position sensor fitting in the picture? thanks.
Jeffy,
It's not the Camshaft but the Crank Shaft Position Sensor. The computer watches the crank to know where the pistons are. Advance the CPS and the computer will think the marks are coming up faster or slower then normal.
