General Forums => The Mess Hall => Topic started by: tallrugbyguy on July 01, 2009, 12:37:10 PM
Title: 97 ax 5 into a 95 yj
Post by: tallrugbyguy on July 01, 2009, 12:37:10 PM
just wondering if anything is different.
its a 97 ax5 trany going into a 95 yj.
thanks. i think 97 is external slave?
Title: Re: 97 ax 5 into a 95 yj
Post by: TahoeYJ on July 01, 2009, 06:30:42 PM
Yep external slave. The 98 AX-5 I just put in is ext. as well  :smokes:
Post by: sharpxmen on July 02, 2009, 11:34:41 AM
my 95 YJ ax5 had external slave as well - not sure about other differences but the slaves are the same
Post by: tallrugbyguy on July 03, 2009, 10:43:17 AM
ok sweet. thanks guys.
if anyone know any other differences please let me know.
Post by: sharpxmen on July 03, 2009, 01:13:17 PM
not 100% but the rubber mount is probably different - i think all TJs have a 4 bolt one (but here I am tallking about the ax15 or NV3550 which are out of the 6 cyl - i do think that the TJs 4 cyl have the same mount though). you can still use the mounts out of the 95 but you need to elongate the holes in them (there is a main one and also have another anti-torque which also holds the exhaust pipe at the other end).
