		General Forums => The Mess Hall => Topic started by: Mittenz on July 07, 2009, 10:35:16 PM
				I want to know if i put Mopar polished stainless valves (P5249880 in mopar catalog) it will help my I4 1994.
 Sorry for my poor english im french from Canada, Québec
				if you also polish your intake and intake runs, if not the difference will be minimal. What that does is improving the volummetric eficciency of your engine - that means it will "inhale" more air for each cycle so then you can increase your fuel amount = more power. You will also need a larger throttle body (quite a bit of threads here about that) and a cold air intake with a high flow filter (otherwise there will be a bottleneck there). Once you do all this you can increase your fuel delivery by either larger injectors (lots of info about that on this site also) and/or an adjustable fuel pressure regulator (fuel return valve) - but here you are on a guessing game unless you use a wideband O2 sensor to monitor and log you air/fuel ratio. If your engine is not apart yet i would start with all the other mods before replacind valves and polishing intake runs. You can also add a performance cam as well if you rebuild your engine if you want to have even more power. Hope this helps.
