General Forums => The Mess Hall => Topic started by: KnightofMopar on August 17, 2009, 04:26:50 PM
Title: A guy from the Dakota World!
Post by: KnightofMopar on August 17, 2009, 04:26:50 PM
Hey guys! To start off I use to have a 90 2.5 YJ that had 33's with a RC 2.5" Suspension lift and a 3inch body lift. Now for my daily driver I have 97 dakota 2.5 l ( doh). I am looking to get her a little more up and go. I am not looking for a race car as I have my 50Trim SRT 4  :beers:.
List of whats on my truck:
-Mopar Stage 3 Cam\
-2.5" Exhaust
-60mm 4.0 Tb
-Custom CAI
Next on the list is to regear. The truck is currently on 255/60/15's and the rear end has a 3.55 in it  :brick:. Still debating on the 4.10 or 4.56. My question is where should I go next on my crusade for a decent " quick town truck" . I am still a little confused on which injectors to get as I have ready a lot of posts of certain 24 lb injectors having issues with the TJ motors like mine. Any help would be great! A turbo might be next year with low boost to add some spunk, but I am hoping I can get it where I want it with the regear and injector help for the experts :D . It is a 5speed btw!
Title: Re: A guy from the Dakota World!
Post by: FourbangerYJ on August 17, 2009, 05:07:04 PM
IMO gearing is going to give you the most noticable improvement. The lower you go the faster you can row thru the gears! But your top end might suffer a bit with a small dia tire, depending on how much freeway you see.
Post by: chardrc on August 17, 2009, 07:41:58 PM
the electric fan swap gives you a noticeable gain...
Post by: Mr_Random on August 18, 2009, 07:57:55 PM
I can agree with this!
gasket/port matching your intake manifold should help a bit, and is basically free.
Throttle response will improve with a 62mm TB, as well as WOT power.
Above all this, a regear will do the best. Most 2.5/5spds come 4.10 stock, but you have a chryco rear-end, so chances are there is very little easy swapability. Depending on the axle, it should have steeper aftermarket gear options.
Post by: sharpxmen on August 18, 2009, 08:50:16 PM
high flow cone filter gave me quite a bit of change along with the 4.0L tb.
