General Forums => The Mess Hall => Topic started by: OH-YJ on August 21, 2009, 12:25:47 PM
Title: 33's with stock gears
Post by: OH-YJ on August 21, 2009, 12:25:47 PM
Happy Friday!  :beers: I will be buying a lift and tires next month and I'm still debating between 2.5" with 31's and 4" with 33's. I want to go ahead and get the 4" because I know I will want to get the bigger tires eventually, but I have D35's and will not be putting money (gears/locker) into those axles when I will (eventually) be swapping them out for an 8.8 in the rear and probably a D44 up front. I just want to know how well she will do with the stock gears, because who knows when I will swap axles.
Title: Re: 33's with stock gears
Post by: 93yjFirstJeep on August 21, 2009, 03:43:41 PM
I ran with the stovk gears on my yj for about 6 mos. You can manage fine as long as you dont get on the freeway often. 60 to 65 is about all she'll handle. and your gas mileage will drop substantially. i got about 14 and then when i regeared to 4.88's, i now get about 19
Post by: jason 00 tj on August 21, 2009, 05:26:54 PM
 I did stock gears and 33's for 8months.
You can forget about fifth gear enless your on a long down hill.
I had to feather the clutch out a bit more from a stop but ya gotta do
what ya gotta do.
   If you can pick up a dana 44 front out of a rubicon it's the best way to go the
factory locker works easy and is dependable.
If i would do my jeep over i would have got a rear 44 from a rubicon and had F&R lockers
and been good to go.        just my .02 cents
Post by: BarneyJeep on August 21, 2009, 05:32:42 PM
i ran 34 LTB for about a year with stock gears
also ran 33" hankooks for the past year
no problems...just cant use fifth and top out at 65MPH
Post by: sharpxmen on August 21, 2009, 07:03:09 PM
ran 33s with stock axles and stock R&P (4.10 or 4.11 not sure) for 6 years and the R&P gave out this year - true about the 5th unless you're fine cruising like a granny, my top speed was higher though but had a high flow filter and 4.0TB, it did drop significantly uphill and with headwind. Oh, and i did quite a bit of offroading but nothing extreme and did it carefully (no clutch dropping/popping or anything like that).
Post by: Torch_Ind on August 21, 2009, 07:28:53 PM
do what you have to do but it's nice to re gear.  I ran 33's with the stock 4.10's forget 5th. and it hard on the clutch dragging off the start.
I run 4.88's and it's a little better then being stock rubber but i'm running 33's. honestly I wanted 5.13's but need a different front diff to pull that off.
I might leave my diffs and just do my transfer case to have multiple ratios.
but budget is budget. Plan to re-gear though "future" you won't want to keep it like that esp if you off road with it.
Post by: jagular7 on August 22, 2009, 10:05:53 PM
What is the timeline for the axles? What bolt pattern will the D44 have? Most to all D44s (other than Rubicon TJ) won't have the 5 on 4.5 bolt pattern. If you install the 8.8 and the D44 front, then you can add a wheel spacer on the 8.8 to match the D44 front. Then you will need to get different wheels to bolt on.
If you really need 33's, check your local 4wd/Jeep club and craigslist for cheap used set. Save your money and start putting together your axles. I'd look for the 8.8 and get that installed. Keep it SUA and you won't have much a problem with axel wrap. It will also accept your current wheels as well. I'd also look to convert your 2-pce passenger axel to a single shaft and use TJ shafts as they have the larger u-joint and it should all be able to get done by you in the driveway. Look at r&p and lunchbox lockers choices, unless you want to go to a case locker. Lunchbox lockers are much cheaper and can be removed for resale if you don't like their street action. I'm running Easy locker up front and LockRight in the rear in my TJ for ~6 years.
Post by: chrisfranklin on August 23, 2009, 08:58:27 PM
The 16 cylinder Bugatti Veyron is an econo car next to my hard-drinking 4 banger :pirate:
Post by: OH-YJ on August 24, 2009, 03:18:32 PM
The timeline is this coming winter. After I get the lift and tires, axels are next on my list. As for the D44, I'm not 100% I'll go with that in the front, but I'm certain of the 8.8. I found a great write up on another site http://www.jedi.com/obiwan/jeep/ford88.html which is great for a beginner such as myself. Are there any recomended axels for the front that would have the 5x4.5 bolt pattern? What gears are you runnning? I know you have an 8.8, but is your front axel stock? i appreciate the help and advise.
Post by: aw12345 on August 24, 2009, 06:43:21 PM
As long as you don't want to go over 4.88 gears your stock highpinion axle is just fine for 33's
Post by: jagular7 on August 25, 2009, 08:22:29 AM
Like what I had suggested, you could look into upgrading your current front set of axle shafts and joint size. Upgrade is to use TJ stock shafts and joints. The difference is not significant and probably not really necessary for a 4cyl on 33's, but it does rid of the 2-pce inner shaft and the problematic vacuum disconnect. Another option to rid of the vacuum dependancy is the use of a cable to provide front axle connection.
Since you have a D30R, the pinion is set above the centerline of the axle and this provide clearance under the front ds. You will be limited to the availability of gear ratios and the abundance of locker choices for the set of axles.
Do a review of locker choices and cost before you regear. Since the diffs will be open, you may want to add a locker. Lunchbox lockers are the easiest for the owner of the vehicle. They basically replace some innards and thus can be removed as well without major diff surgery.
Yukon has recently introduced their version of one - Spartan. Aussie and LockRight are others. Not sure if EasyLocker is still available.
Post by: Bill M. on September 23, 2009, 02:04:08 PM
I just recently got a set of 33x12.5 procomp AT'S.. Great tire... Well I am running stock 4.11s, and I can still run 70-80 on the highway, depending on the wind. That is verified with a GPS. As for power, in town, I have just enough... I'd like a little more on the highway, but it is 100% liveable...
Post by: jfrabat on September 24, 2009, 04:37:56 PM
I'll second this opinion; I ran 31's with 4.10, and the Jeep felt underpowered.  Then I regeared to 4.88 with 31's, and fell in love.  Then I replaced the 31's with 33's, and I started wishing I had 5.13's, but I am stuck with 4.10 because of the axles...  Even though numerically, 4.88 and 33's will be almost the same as stock, you need to consider wind and rolling resistance of a bigger and heavier tire (hence why I wish I had 5.13's), so in reality, 4.88 is a little WORSE than 4.10 with stock rubbers.
Post by: Torch_Ind on September 24, 2009, 04:41:59 PM
 :thumb:
and I think he meant stuck with 4.88's cause mine is the same as his the yj won't support 5.13's in the front diff
Post by: jcsanders79 on September 24, 2009, 08:22:52 PM
I wouldn't do it.   I think 33's need 4.88's.
Post by: drunkencityworker on September 25, 2009, 06:37:09 AM
I would say get 33s then regear. loss of power will motivate to get it done. skip the waste of time and money w 31s. front goto tj no disco shaft and locrite. locrite from dana35 will work up there
Post by: drunkencityworker on September 25, 2009, 06:39:26 AM
as i always say be patient and check cl and local jeep forums for good deals on used stuff. if u ever go with44 yyou can get superior axles for 8.8 with 5.5 pattern. i cant wait to regear
Post by: jfrabat on September 25, 2009, 08:38:15 AM
 :thumb:
Front or rear; I still got the D35 (I got alloy axles in it so it'll hold the ARB locker, but I'd be risking it if I go to 35's).
I would say go the other way; first regear, then change tires...  I went that route and dont regreat it (but then again, my Jeep came with 31's...)
Post by: rubberducky on September 29, 2009, 09:21:03 PM
I run 33's with stock 3.73 in my 05 w/2 inch lift. Have 108k original owner. Top out around 75 cruise at 70 in fifth. never use sixth. Pull loads, long trips, you name it. If you drive hard accelerate hard or wheel hard I don't think you should do it. If you drive easy no hard wheel by all means do it. Have blown out rear spider gears and my front axle u-joint is going out, all my suspension bushing are going. I blame spider gears and bushings on pulling heavy loads 1-2k every week. yea dont pull weight with these little tonkas.
I also have home made cold air intake, throttle body spacer, and a chip.
Post by: jeeper78 on September 30, 2009, 12:04:03 AM
I am runnin a 97 TJ with "Bountyhunters" 62mm throttle body and spacer and I'm also running the stock drivetrain with the ax5 and 4:10 gears. I run BFG 33x10.5 at's and I don't really have many problems on the highway. (top speed around 75 mph). I think you should go with the 4 inch lift and get the suspension basics over with. Get a set of skinny 33's for the street and later you can get a set of aggresive tires when money permits.
Post by: Torch_Ind on September 30, 2009, 08:16:33 PM
I added pictures of my jeep growing to help you decide on your lift but I think you should do the 4 inch right away don't bother with the 2.5" and re-gear at anything over 31's
(http://photos-f.ak.fbcdn.net/hphotos-ak-snc1/hs261.snc1/8824_144308432028_504452028_2805573_7277391_n.jpg)
bone stock
(http://photos-d.ak.fbcdn.net/hphotos-ak-snc1/hs241.snc1/8824_144306032028_504452028_2805563_5948945_n.jpg)
stock on 31's
(http://photos-e.ak.fbcdn.net/hphotos-ak-snc1/hs261.snc1/8824_144306362028_504452028_2805564_4646096_n.jpg)
4 inch lift on 31's!
(http://photos-c.ak.fbcdn.net/hphotos-ak-snc1/hs261.snc1/8824_144307072028_504452028_2805570_3215040_n.jpg)
4 inch lift 33's
going to do body or over axle to gain a little more flex so I don't rub so much. but don't plan on going any bigger on tires.
Post by: neale_rs on October 01, 2009, 08:52:31 AM
Good plan.  Going bigger than 33s starts to require more spending, upgraded front shafts, more breaking now and then, etc.  It has happened to a lot of local Jeeps.
Post by: Torch_Ind on October 01, 2009, 03:03:07 PM
so true.
even 33's on it with the stock set up if you drive like a retard at mock chicken through stuff boom crack bang and oh no!!
most of my local group anyone running a jeep with bigger then 33's won't travel anywhere more then a few miles because it handles bad and there suspension is beat out of it pretty bad from wheeling!
http://bayareawheelers.ca  local group of ours here North bay, Ontario.
Post by: Torch_Ind on October 02, 2009, 01:41:46 PM
The last pic looks perfect...
Those 4 inch lift and 33's tires makes that rig more sweeter...
I want to flat fender and open up the wheel wells possibly do a body lift. but will see I might get the clearance I want with flat fendering it.
Post by: FourbangerYJ on October 02, 2009, 02:05:27 PM
Weird! I have driven my junk all over running 31-37's. I love driving it!
Post by: Mozman68 on October 02, 2009, 02:44:34 PM
running 35's with a long arm 4" lift feels better than stock for me.
Post by: Torch_Ind on October 02, 2009, 04:23:47 PM
lol ya don't bother me to drive mine anywhere. some people are special lol
