General Forums => The Mess Hall => Topic started by: Jeffy on November 04, 2009, 09:25:42 PM
Title: Internet Deals Thread
Post by: Jeffy on November 04, 2009, 09:25:42 PM
FYI: Seems that Amazon.com has dropped the price for the Fram Air hogs to $8.98.  Pretty good deal since paper filters cost about the same.
Title: Re: Fram Air Hogs $8.98
Post by: vprsrul on November 05, 2009, 04:22:00 PM
a buddy of mine sucked a fram airfilter(it was the regular one) into his turbo, truck was a 04 duramax.... the filter media came all to pieces, the fram tough gaurd oil filter that fits my jeep also had issues, the media collapsed and blew the filter right off the jeep... and wasted 4 fresh quarts of oil!!! glad I noticed it right as it happened and shut it off and fixed it.
Post by: Jeffy on November 05, 2009, 05:17:49 PM
These are not paper filters and should be of higher quality.
Post by: C.Redbeardd on November 05, 2009, 05:41:22 PM
Question... If i wanna buy one off of amazon how do i know which one is for my application? 1990 yj 2.5
Post by: Jeffy on November 05, 2009, 05:42:19 PM
There's a vehicle selector someplace.  Otherwise you should be able to go to Fram and they should have a catalog.
I just looked it up at Fram, which happens to be the same filter for later YJ's.
YJ - Part Number PPA3373
Product Type   Air Hog Air Filter
Product Height   1.56"
Product I.D.   5.28" (Width)
Product O.D.   13.16" (Length)
TJ - Part Number PPA8205
Product Height   1.98"
Product I.D.   6.22" (Width)
Product O.D.   13.5" (Length)
Style Code   486
XJ - Part Number PPA3901
Product Height   1.59"
Product I.D.   6.63" (Width)
Product O.D.   13.55" (Length)
Style Code   486
Post by: C.Redbeardd on November 05, 2009, 05:59:15 PM
Cool, any idea where i can pick up the cleaner for this? And/or if I can use K&N cleaner for it?
and oil of course.
Post by: Jeffy on November 05, 2009, 06:41:18 PM
and oil of course.
I suspect it's similar to the K&N although they do have their own brand stuff.
General Service Notes:
Inspect filter every 6 to 12 months. If the filter has a visible layer of dust, it should be serviced. If the vehicle is operated in severe or high dust conditions, more frequent inspection and service will be required. Never let the filter go beyond 18 months without cleaning.
Prolonged exposure to heat or sunlight may cause the filter to dry out. If the filter appears too dry, but does not require cleaning, a light application of oil is recommended.
Do NOT saturate the filter with oil – it could be harmful to the vehicle’s air induction system.
Directions for Use:
A. Cleaning -
When cleaning your FRAM® AirHog™ filter, NEVER use gasoline, cleaning solvents, steam, caustic solutions or strong detergents. Do NOT use brush or tools to facilitate cleaning. NEVER spray filter with compressed air or high-pressure water. Always use slow flowing, cool water to rinse filter. Failure to follow these safeguards may result in damage to the filter media.
1) Carefully remove the filter from the filter housing. Inspect and clean filter housing prior to re-installing the filter.
2) Tap the filter against a flat surface to remove any loose or caked-on dirt. Take care not to contaminate the clean side of the filter element.
3) Place filter on a flat work surface and spray both sides of the filter liberally with FRAM™ AirHog™ Air Filter Cleaner. Allow the solution to soak into the filter media for at least 10 minutes.
4) Rinse the filter using cool. low-pressure tap water. Rinse from the clean side.
B. Drying -
Allow filter to completely dry naturally. NEVER use compressed air, heat or open flames. Heat may cause the filter media to shrink. Failure to follow these safeguards may result in damage to the filter media. It is very important that the filter media is dry prior to re-oiling.
C. Oiling -
When oiling use only FRAM® AirHog™ Air Filter Oil. NEVER use filter without oil. The oil is needed to remove contaminants. Do NOT over oil filter. Failure to follow these safeguards may result in damage to the vehicle.
1) Before applying FRAM® AirHog™ Air Filter Oil, inspect the filter to ensure that it is clean and dry. If necessary, a second cleaning may be required.
2) Sparingly apply filter oil to each pleat. Spray each pleat only once. You will be able to see where the oil has been applied because the filter media color will change to FRAM™ orange. Only a light covering of oil should be applied, do NOT saturate the media.
3) Allow the oil to soak into the filter for 20 minutes. If after 20 minutes any white spots remain, lightly re-apply oil in white areas only.
4) Re-install the filter into the clean filter housing/airbox. Ensure that the sealing surfaces are properly seated
5) Affix the "Do Not Discard" sticker in a highly visible location on the outside of the filter housing to prevent a service technician from discarding your FRAM™ AirHog™ air filter.
Post by: C.Redbeardd on November 05, 2009, 06:57:50 PM
i read that too but i suspect they say only use there brand because they want to make the money off you. Thats my 2 pennies on that. Thats why i ask. haha
Post by: dwtaylorpdx on November 05, 2009, 08:54:00 PM
I used to use simple green to clean the filter, mixed it 1 part soap
to 5 parts water and soaked the filter in it. Then just use a garden hose
with one of these "gentle" spray nozzles for flowers to rinse it out.
The simple green only needed like 2 minutes to break everything loose.
Post by: C.Redbeardd on November 06, 2009, 12:16:48 AM
But what did you use to oil it? :confused:
Post by: vprsrul on November 06, 2009, 08:41:40 AM
air hogs need oil?  I never knew they were like k&n filters....
Post by: C.Redbeardd on November 06, 2009, 10:14:42 AM
Yeah I ordered one from amazon. Gonna try it out, see whats up with it. However, when I go wheeling, the paper filter is going back in.
Post by: vprsrul on November 06, 2009, 11:31:33 AM
good idea, biggest reason I dont like to use these type of filters.
Post by: Jeffy on November 06, 2009, 12:39:34 PM
They are reusable filters like the K&N.  Several of us bought them when they were -$1.  ie. you made $1 after sending in a coupon.
(http://4bangerjp.com/forums/index.php?action=dlattach;topic=3684.0;attach=389;image)
Post by: Jeffy on November 06, 2009, 01:02:42 PM
Looks like Purolator oil filters are also on some sort of sale.
PH8A - http://www.amazon.com/Purolator-L30001-Classic-Filter-Pack/dp/B000ICNU9S/ref=sr_1_1?ie=UTF8&s=automotive&qid=1257537143
They don't seem to have the larger one in stock though.
Post by: C.Redbeardd on November 06, 2009, 01:49:33 PM
What are the specs for that oil filter?
Post by: Jeffy on November 06, 2009, 02:00:07 PM
It's equivalent to a Fram PH8A
Post by: C.Redbeardd on November 06, 2009, 03:20:53 PM
Gotcha.
Post by: Jeffy on November 06, 2009, 05:14:44 PM
Gotcha.
The stock is a PH16, IIRC and there is also a larger filter.  PH997a or something like that.  It's all in the FAQ.
Post by: C.Redbeardd on November 06, 2009, 08:40:29 PM
Yeah I'll check it out. Only problem is I just changed the oil fairly recently hahaha.
Post by: Jeffy on November 06, 2009, 11:12:21 PM
Stock up!  I usually have one or two extras around just in case I feel the need.  It's pretty easy to change the oil since I have a Fram Suredrain which adds a wang to the oil pan so I can drain it directly into bottles.
Post by: C.Redbeardd on November 06, 2009, 11:39:49 PM
dang never heard of that. haha. Anyway, never really felt the need to stock up on oil filters as I can get them for fairly inexpensive at any nearby autoparts store haha. I usually pick one up when I grab oil. I dont really have anywhere to store much of anything as of right now anyway.
Post by: vprsrul on November 08, 2009, 08:09:30 PM
those are great, I have a similar one made by fumoto.
Post by: FourbangerYJ on November 09, 2009, 10:03:48 AM
Wish I had something like that. I have to drop my engine skid to change the oil. It does not take that long, but it's a PITA.
Post by: Jeffy on November 09, 2009, 01:10:05 PM
I'm not sure why Fram doesn't have them on their site anymore but you can still find them at a lot of online vendors.  It's around $8.  I don't remember which model number it is but I think it's SD1 or SD2.  I'm thinking it's SD1 since it's standard and not metric like all of the others.  FRAM/JEG's application chart is a bit confusing.  http://www.jegs.com/pdfs/SureDrain.pdf
SD1- 1/2-20 Oil Drain - http://www.amazon.com/Fram-SD1-SureDrain-Access-Change/dp/B000AMW0K6
SD2 - M14x1.5 Oil Drain - http://www.amazon.com/Fram-SD2-SureDrain-Access-Change/dp/B000AMW0JW
SD3 - M12x1.25 Oil Drain
SD4 - M12x1.75 Oil Drain
SD5 - M18x1.5 Oil Drain
Post by: FourbangerYJ on November 09, 2009, 02:21:09 PM
Looks like a SD1 would work for me. How long does it take for the oil to drain out? I have heard it's pretty slow.
Post by: zowtiak on November 09, 2009, 04:33:52 PM
Good stuff and thanks. Amazon has a good outlet as well and sometimes things get dirt cheap. I wonder what the difference is in the orange filter versus the white filter?
Post by: zowtiak on November 09, 2009, 04:49:45 PM
I went looking and amazon also has a great deal on besttop bikini tops. $22.30. The rest are $53!
  :http://www.amazon.com/Bestop-52519-37-Strapless-Bikini-Spice/dp/B0002SA410/ref=au_pf_ss_2?ie=UTF8&n=15684181&s=automotive&carId=001 (http://:http://www.amazon.com/Bestop-52519-37-Strapless-Bikini-Spice/dp/B0002SA410/ref=au_pf_ss_2?ie=UTF8&n=15684181&s=automotive&carId=001)
It says they only have 2 in stock. I bouight shocks once when they had 2 in stock. They got more, but tripled the price.Just saying that it might be good to pull the trigger.
Also, amazon has THE best price on the Fram Sure Drain. SD1 fits the 2.5 pan. $7.69
 :http://www.amazon.com/Fram-SD1-SureDrain-Access-Change/dp/B000AMW0K6/ref=sr_1_4?ie=UTF8&s=automotive&qid=1257810556&sr=1-4 (http://www.amazon.com/Fram-SD1-SureDrain-Access-Change/dp/B000AMW0K6/ref=sr_1_4?ie=UTF8&s=automotive&qid=1257810556&sr=1-4)
Title: Re: Internet or Local Deals Thread
Post by: Jeffy on November 09, 2009, 05:20:31 PM
I changed the topic to include any deals you find and want to share.
Post by: zowtiak on November 11, 2009, 01:53:51 PM
Will these fit the jeep yj with 2.5 l engine?
Title: Re: Internet Deals Thread
Post by: C.Redbeardd on November 11, 2009, 03:13:44 PM
well this is a forum for 4 cylinder jeep engines. I'd say, yes. lol
Post by: Jeffy on November 11, 2009, 04:21:08 PM
http://4bangerjp.com/forums/index.php/topic,390.html
Post by: sharpxmen on November 11, 2009, 04:53:46 PM
10% off Veteran's Day Sale at 4wd.com
Promo code VET09
thought i'll share, just got an email.
EDIT: apparently you have to call to get the discount 1-800-914-0065 valid Wed Nov 11 and Thu Nov 12, 2009.
tires seem to be on sale already when you buy 4 you get $100 off, not sure if this code apply to that already discounted deal, if it does it's the best price on tires i've seen - 4 x BFGoodrich Mud-Terrain T/A KM2 Tire, 35x12.50R15 show in cart at $707, if this veteran's day promo apply then would be $637 = $159/tire - quite a deal for those (again not sure if you can redeem that code but if you can it's worth the call)
Post by: zowtiak on November 11, 2009, 09:40:00 PM
I couldnt agree more. I did go to the purolater site before putting in my newbie question and checked to see if the 30001 would work. I diligently spent about 20 minutes doing a "next" button marathon and when I got to jeep it did not show it as compatible. But i am glad i am wrong because i am going to get a pair of the filters to go with my air hog and sure drain.
Post by: C.Redbeardd on November 11, 2009, 09:45:13 PM
I ordered an air hog. I should be recieving it tomorrow.
Post by: Jeffy on November 11, 2009, 10:16:13 PM
It won't shot it as matching because it's not the stock size.  These are over-sized so they are not recommended by the mfg.  Many of us have been running the PH8A style filter for years.  It's slightly larger then the stock PH16.  I would recommend going with a PH997A (I think that's the one in the faq).  That is more then twice the size of the PH16.  Amazon does not have a sale on them though.  They aren't as common as the PH8A.  Seems most everything uses a PH8A.
Post by: dwtaylorpdx on November 11, 2009, 11:24:06 PM
When you install the larger filter check the clearance between it and the motor mount. On my 94 the original mounts were like 1/8 inch from the filter, I noticed a dent in the filter from impact from wheeling. Once I replaced the mount (Another failure) it was different and had plenty of room.
Post by: C.Redbeardd on November 16, 2009, 02:03:23 PM
Question: Where can i find the fram air hog cleaner and oil kit?
Post by: Jeffy on November 16, 2009, 03:26:32 PM
http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=FRA&MfrPartNumber=PK1&CategoryCode=3335I
Post by: zowtiak on November 16, 2009, 11:50:38 PM
I pulled the trigger on the airhog and it should be here soon. do i need to oil it first?
Post by: vprsrul on November 17, 2009, 09:15:30 AM
should be oiled from the manufacturer.  if not you will be able to tell.
Post by: zowtiak on November 17, 2009, 07:12:35 PM
Thanks. I read earlier that it should be orange too.
Post by: dwtaylorpdx on November 20, 2009, 11:55:44 PM
the oil form the manufacturer is just to preserve it,
they should have a booster oil done before install.
At least thats how K&N and Uni-filter are installed.
Post by: Jeffy on November 21, 2009, 01:44:20 PM
Hmm, the Fram is Drop-In and go.  I don't think K&N's require additional maintenance out of the box or else a large majority of people aren't installing them properly.
Post by: sharpxmen on November 21, 2009, 06:57:00 PM
thought so too, my Apollo's instructions only mention to service it after whatever miles but does not say to add any oil for the first install.
Post by: dwtaylorpdx on November 22, 2009, 02:53:37 PM
You hit it right on the head,   :biggrin:
MOST PEOPLE DON'T INSTALL THEM PROPERLY!
Its like 2 pages into the instructions that you need
to oil the K&N before installing it. I play at a race shop
and do a lot of weekend work wrenching on race cars,
I've literally installed a hundred of these in the last 10 years.
For a while the K&N's did come pre-oiled in a sealed bag in the
box and they dripped oil when you unpacked them. But the only
ones I saw like that were the round SBC style for stock air cleaners and
a few of the ones like fit the YJ air box.. But recently have all come almost dry.
I like the foam filters better cause they are easier to clean, but the Unitfilter style
are about double the price of a K&N and in road racing the dirt is not a big deal,
many guys run without filters at all especially on the really high winding Weber
side draft equipped engines. They just have a 1/4 in grid trash screen.
Post by: sharpxmen on November 22, 2009, 04:34:56 PM
i will call them tomorrow - the Apollo is an enclosed filter, comes assembled, I will have some words for them if you are right and i need to take it apart and oil it. I'll post back once i get hold of someone at KnN
Post by: Jeffy on November 22, 2009, 04:52:25 PM
I know the Airhog is ready to go as they are bagged inside the box to keep them fresh.
Post by: dwtaylorpdx on November 22, 2009, 11:33:54 PM
I'll be interested to see what you find out!
I've always thought it kind of sucked that you had to
buy the oil before you could use the filters.
I installed a big K&N on a sprint car a couple months ago it
came white, no oil at all. and it was huge, took almost a full bottle of oil to get it covered.
I also wonder if there are many counterfit K&N filters in the market, there are
definitely several fabric based filters that look identical but sold under import brand names.
Would not be the first company to have that happen....
Post by: Jeffy on November 22, 2009, 11:55:37 PM
There are knockoffs.  Look at the import scene and you'll find them.  Most are cheap no-name brands.
Post by: dwtaylorpdx on November 23, 2009, 12:45:46 AM
Yea, but ya gotta wonder how many end up in a K&N box printed offshore.....
Hmm I need to tool through  a couple of the cut-rate auto parts stores this week and take a look.
Post by: sharpxmen on November 23, 2009, 08:30:24 AM
white K&N?  :puzzled:
Post by: jfrabat on November 23, 2009, 08:45:29 AM
Mine was not white either...
Post by: chardrc on November 23, 2009, 09:10:34 AM
all the K&Ns ive seen/ used aren't white...
Post by: sharpxmen on November 23, 2009, 09:28:00 AM
that's what happens if you shop at flea market  :roflol:
just j/king Dave - you sure it was a KnN?
Post by: dwtaylorpdx on November 23, 2009, 01:19:58 PM
Yep ordered right from them direct, a 400 dollar 15" tall, 15 Wide 28" Long box filter.
It was not pure white, if you held it up in the light it had a very faint tinge of
red-purple like they had misted the oil on to it. But once I oiled it its K&N red now...
Took almost eh whole 16ox bottle of oil to get the beast oiled up. I'll try and snap
an Iphone pic its pretty impressive....
Post by: sharpxmen on November 23, 2009, 01:42:35 PM
you have this on your Jeep? Yeah, pics please.
Post by: dwtaylorpdx on November 23, 2009, 04:40:30 PM
Naw, its on a 800 HP wingless sprint car with Hillborn Injection running on Methanol...
There is NO substitute for Power to weight. 800HP and 1200 Lbs with driver...
90 mph sideways on a 1/8 mile oval.... Wheelie on demand...
Post by: sharpxmen on November 23, 2009, 05:32:57 PM
oh, ok  :lol:
Title: I know we got the internet deal thread, but...
Post by: zowtiak on January 20, 2010, 11:42:49 PM
amazon has spice colored bikini tops for only $18.75. sweet deal.
http://www.amazon.com/Bestop-52519-37-Strapless-Bikini-Spice/dp/B0002SA410/ref=au_pf_ss_9?ie=UTF8&n=15684181&s=automotive&carId=002
Post by: neale_rs on January 22, 2010, 12:29:24 PM
This is one of the best deals I´ve seen on a good quality snatch block (ARB 209):
http://cruisersolutions.com/index.php?main_page=product_info&products_id=167
The ARB shackles are also about the cheapes available although they are kind of rough looking.
Title: throttle body spacer deal
Post by: countryboy15 on February 08, 2010, 06:30:14 PM
I found out about this deal from the people who sold me my throttle body spacer on ebay for $35 shipped. They put a piece of paper in with the TB spacer I ordered and it had this wedsite listed on it.
http://www.intakespacer.com/ (http://www.intakespacer.com/)
The qoute below is from ther homepage.
Quote
FREE SHIPPING/HANDING IN THE "USA".
  Helix and Swivel Spacers $35.00.
  Plain Spacers $30.00 . (with free shipping in the u.s.a.) WORLDWIDE SHIPMENTS ADD $15.00 .
 SPACER IS DESIGNED TO ADD 4-6 MORE HORSE POWER AND IMPROVE GAS MILEAGE 2-4 MPG MORE!! BETTER THROTTLE RESPONSE, 50 STATE LEGAL.! ONE OF THE BEST BOLT ON'S EVER DESIGNED, UPGRADED FOR YOUR DOLLARS AND THIS IS A UPGRADE THAT CAN BE ACCOMPLISHED IN LESS THEN 30 MINUTES. ALL SPACERS PERFORM THE SAME!!. WE LIKE THE PLAIN ONE BECAUSE , MORE AIR = MORE POWER BUT THE HELIX AND SWIRL SPACERS GIVES YOU A LITTLE BETTER SOUNDING MOTOR. WE HAVE OVER 25 YEARS EXPERIENCE, SPACER IS FULLY CNC MACHINED FROM 6061 ALUMINUM. OUR KITS INCLUDES EVERYTHING NEEDED TO INSTALL. "MADE IN THE USA". SHIPPING/HANDING IS FREE IN THE USA. WE SHIP PRIORTY MAIL 2-3 DAYS FLATE RATE ENVELOPE IN THE USA, WORLDWIDE SHIPMENTS ADD $15.00. WE HAVE TECHNICAL SUPPORT FOR ALL YOUR QUESTION, PLEASE E-MAIL US WITH ANY QUESTIONS YOU MAY HAVE RES069TU@GTE.NET. WE PRIDE OUR SELVES ON OUR LIGHTNING FAST SHIPPING. WE SHIP SAME DAY PAYMENT RECEIVED, ""MOST"" OF ARE CUSTOMERS RECEIVE THERE SPACER IN 2-3 DAYS!!!.. WE ACCEPT PAYPAL, MONEY ORDERS, CASHIERS CHECKS AND PERSONAL CHECKS. (PERSONAL CHECKS MUST CLEAR FIRST, 4 TO 10 DAYS). Pay me securely with any major credit card through PayPal!
PLEASE READ SOME OF OUR POSTIVE FEEDBACK
this is the coolest part ive put on my truck yet A++++ thanks!!!!
A++++ Fit right on my jeep wrangler only took me 20minutes to install!!! THANKS!
Took me from 13.5 to 18.8 MPG. worth it and good transaction!
as a retired machinist this is good quality work.AAA+++
nice product fast shipping knowledgeable staff thanks!!!!!!!!
Title: Re: throttle body spacer deal
Post by: sharpxmen on February 08, 2010, 07:01:56 PM
thanks for sharing
price is good but the ad is stupid - 4 to 6HP and 2 to 4mpg is a lot of BS.
Post by: countryboy15 on February 08, 2010, 07:32:27 PM
thanks for sharing
No problem I just thought others who are looking for a throttle body spacer would like to know. Yea, I know the ad has alot of BS, but has some stuff to make people realize the throttle body spacer site isn't a scam.
Post by: sharpxmen on February 08, 2010, 08:17:51 PM
that's good, like i said - thanks for sharing. i was just surprised by the claims but i guess it has to compete on ebay so that's probably why
Post by: FourbangerYJ on April 17, 2010, 07:14:45 PM
I didn't notice this was not a sticky any more...
Anyway I got an email from Polyperformance Not sure if this code will work more than once or not.
 SAVE 10% on your entire ONLINE ORDER when you use the following discount code.
Code: 6D2010
Questions? Contact Customer Service at 805.783.2060
Shop Online at http://www.polyperformance.com
Title: k&N filter om amazon...$22!
Post by: zowtiak on April 24, 2010, 03:15:32 PM
I am not sure if this is the right place to post...I was looking for a K&n for a homemeade CAI. Amazon has a new one for $22.
here is the linky
http://www.amazon.com/RC-4630-Universal-Chrome-Filter/dp/B00029WZ0C/ref=au_pf_ss_1?ie=UTF8&n=15684181&s=automotive&carId=001 (http://www.amazon.com/RC-4630-Universal-Chrome-Filter/dp/B00029WZ0C/ref=au_pf_ss_1?ie=UTF8&n=15684181&s=automotive&carId=001)
Title: Re: k&N filter om amazon...$22!
Post by: sharpxmen on April 24, 2010, 07:47:43 PM
here is the linky
it's a good deal for the price, the only problem is that it is for a 3.5'' intake pipe so you would need a reducer to 2.5''. still, $22 for a KnN cone filter is not bad.
Title: LED 4" Tail Light on Sale
Post by: aka-justin on April 30, 2010, 09:17:34 PM
Harbor Freight loward the price to $5.87 on there 4" round LED light.  I'm picking up a set this weekend.  The manual looks like it's a 3 wire, w00t!   :weee:
4" Submersible LED Stop/Turn Trailer Tail Light with Flange Mount
http://www.harborfreight.com/4-inch-submersible-led-stop-turn-trailer-tail-light-with-flange-mount-94795.html (http://www.harborfreight.com/4-inch-submersible-led-stop-turn-trailer-tail-light-with-flange-mount-94795.html)
(http://www.harborfreight.com/media/catalog/product/cache/1/image/370x/9df78eab33525d08d6e5fb8d27136e95/i/m/image_3065.jpg)
Post by: Bounty Hunter on May 01, 2010, 07:46:22 AM
Collins Brothers Jeep has these cool Bestop storage boxes on clearance, normally $130pr and now $30pr +shipping.  Fits '92-'95 YJ and available only in black.  Click on Bestop Closeouts. http://www.collinsbrosjeep.com/main.htm
(http://razmear.us/jeep/g05.jpg)
Post by: Jeffy on May 21, 2010, 08:49:40 PM
Here's a really good deal for someone wanting a trail-use GPS.  It's a older style GPS that does streets but it's a bit small for using the turn-by-turn.  It's awesome on the trails and comes with TOPO's.
http://www.cabelas.com/cabelas/en/templates/links/link.jsp;jsessionid=3INQRI0D2AX2PLAQBBKSCO3MCAEFAIWE?id=0036479229052a&type=product&cmCat=SEARCH_all&returnPage=search-results1.jsp&Ntt=garmin+60csx&Ntk=Products&sort=all&Go.y=0&N=0&Nty=1&hasJS=true&_dyncharset=ISO-8859-1&_DARGS=/cabelas/en/common/search/search-box.jsp.form1&Go.x=0&_requestid=47271
Post by: Jeffy on May 21, 2010, 08:54:58 PM
Here's one for the GPS itself without TOPO.
http://www.basspro.com/webapp/wcs/stores/servlet/Product_10151_-1_10001_73617____SearchResults
Post by: aka-justin on May 24, 2010, 07:08:53 PM
I've been looking for a copy of the CA topo by National Geographic. Let me know if you happen to spot it ;)
Post by: Jeffy on May 24, 2010, 07:38:05 PM
I have Garmin's Topo.  Unlike the Navigator, it's unlocked.
Title: Harbor Frieght 20% off
Post by: aka-justin on June 03, 2010, 11:57:21 PM
Harbor Frieght Coupon, good till 6/16/2010
http://www.harborfreightusa.com/html/MagazineLanders/5-outdoor/images/20_c.jpg
(http://www.harborfreightusa.com/html/MagazineLanders/5-outdoor/images/20_c.jpg)
Post by: enginethatcould on June 29, 2010, 05:12:54 PM
Smittybilt XRC full coner guards $204.45 w/ free shipping
http://4wheelonline.com/jeep/Products.aspx?CategoryId=93556&ProductId=445223
Post by: FourbangerYJ on July 02, 2010, 08:19:41 PM
Poly Performance Independence Day - Weekend Savings!
Poly Performance is full-on into the start of Summer. We are offering a Independence Day - Weekend Savings to all our special customers and friends. Don't hesitate - offer good through 12AM PT 07/05/2010. *some restrictions apply
SAVE 10% on your entire order ONLINE when you use discount code: 4JULY2010
Post by: FourbangerYJ on July 21, 2010, 09:26:35 PM
   $100 Mail-in Rebate!
July 23rd and July 24th, 2010, receive a $100 Mail-In Rebate when you purchase any set of four tires or four wheels installed at your nearest California Discount Tire or America's Tire store.
This offer can not be combined with any other promotional offer.
Post by: Eucalypta on October 14, 2010, 08:40:07 AM
Rockauto has some nice discounts on parts:
1991 Wrangler: http://www.rockauto.com/RSS/vehiclefeeds.php?carcode=1185005&m=wc&l=en&html=true
1994 Wrangler: http://www.rockauto.com/RSS/vehiclefeeds.php?carcode=1185207&m=wc&l=en&html=true
Post by: Jeffy on November 21, 2010, 12:06:12 AM
http://www.amazon.com/Smittybilt-97281-XRC-Black-Winch/dp/B001CF1Y0C/ref=pd_ys_home_shvl_148
Seems like a good deal, especially with free shipping.
Post by: Jeffy on November 21, 2010, 12:16:40 AM
Seems they have a few deals going on.
http://www.amazon.com/gp/product/B0030E067U/ref=s9_simh_gw_p263_d0_i3?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-3&pf_rd_r=1NNCER06F2RZE661YAR4&pf_rd_t=101&pf_rd_p=470938811&pf_rd_i=507846
http://www.amazon.com/gp/product/B0030E5HS8/ref=s9_simh_gw_p263_d0_i5?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1PMPEFDRATT6XNR4DD6P&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
http://www.amazon.com/Superwinch-1585202-LP8500-Series-Winch/dp/B0030E5HS8/ref=sr_1_15?s=automotive&ie=UTF8&qid=1290323656&sr=1-15
http://www.amazon.com/gp/product/B001CF1XYY/ref=s9_simh_gw_p263_d0_i3?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0CXX260SMRPA28242Y7B&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
http://www.amazon.com/gp/product/B000182DYM/ref=s9_simh_gw_p263_d0_i5?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1RJ1RJTT84H6MAXJZKAB&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
http://www.amazon.com/gp/product/B000OV6L2Q/ref=s9_simh_gw_p263_d0_i5?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0Z7XC4QRWJQWH7GR75A6&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
Post by: chrisfranklin on November 21, 2010, 08:00:09 AM
Picked up a Coolant Temperature Sender using these links.  Thanks  :biggrin:
Post by: Jeffy on November 21, 2010, 02:00:17 PM
Anyone looking for a 50/70/120/150a resetable breaker might want to check these out.  $29.99 is a good price for these.
http://www.powerwerx.com/fuse-holders-fuses/resettable-circuit-breaker-cooper-bussmann.html
Post by: Jeffy on November 21, 2010, 11:33:55 PM
YJ wiper blades $4
http://www.amazon.com/Trico-Products-12-2-Exact-Wiper/dp/B000CB6A88/ref=wl_it_dp_o?ie=UTF8&coliid=I8Y0P8TM42NY0&colid=WG3JTMMB3ZB8
Post by: FourbangerYJ on November 28, 2010, 09:12:54 AM
POLY PERFORMANCE CYBER MONDAY SAVINGS!
Don't hesitate - offer ends 12AM PT 11/30/2010. *some restrictions apply
SAVE 10% on your entire ONLINE ORDER when you use discount code: CYBER10
Post by: Jeffy on November 28, 2010, 12:31:28 PM
That would be good to use on some axles.
Post by: FourbangerYJ on November 28, 2010, 09:59:02 PM
Not sure what the restrictions are on the discount. But ya 10% off some axles would be good.
Post by: FourbangerYJ on December 03, 2010, 07:32:06 PM
http://store.avhost.net/mountainoffroad/special_list.aspx?v=3&so=0
20% off everything until Christmas.  :thumbsup:
Post by: Jeffy on December 03, 2010, 07:33:11 PM
They're still expensive though.   :wall: :lol:
Post by: aka-justin on December 04, 2010, 12:52:58 AM
http://www.4wheelparts.com/special-deals.aspx?deal=1318
K/C HiLites Lights
Up to $20 Instant Rebate w/Purchase of K/C HiLites
Product Savings
Select Lights $10 Instant Rebate
Light Bars $20 Instant Rebate
(http://www.4wheelparts.com/aux_incl/images.ashx?i=webcontrols%252fpromotionpagecontrols%252fimages%252f1318.jpg)
Post by: enginethatcould on December 31, 2010, 10:39:42 AM
BTF is running some specials right now that include DIY tube fenders for CJ, YJ, and TJ- $159.99 REG. $219.99
http://bluetorchfab.com/store/specials.php?page=2
http://bluetorchfab.com/store/specials.php?page=3
Post by: FourbangerYJ on January 23, 2011, 10:18:14 AM
Here is a free shipping code for http://www.cabelas.com/ghome.jsp?rid=0123456789
This code is only good for Feb 4-6 2011
Enter YNRASHIP in the promotion code upon check out.
I love that place  :thumbsup:
Post by: FourbangerYJ on January 29, 2011, 10:19:40 PM
http://www.discounttire.com/dtcs/findPromotions.do?pgid=427&utm_source=Avimail&utm_medium=email&utm_campaign=AvimailJan2911NtnwideBFG50Promo
$50.00 mail in rebate for and set of 4 BFG's through America's tire - Discount tire.
Post by: Jeffy on March 15, 2011, 01:18:59 PM
(http://www.discounttire.com/images/WePayTheTax.jpg)
Post by: Green97TJ on March 20, 2011, 09:44:17 PM
Was looking for a catback system for my TJ  Found Dyno-Max for 149.95 with 75.00 rebate   most art about 40 to 50 more...
 http://www.summitracing.com/parts/WLK-17345/
Title: Re: Internet Deals Thread - Cash Rebate on Warn winches at Quadratec
Post by: sharpxmen on July 25, 2011, 11:55:48 AM
$80 cash rebate on Warn winches at Quadratec
http://www.quadratec.com/products/product_search.php?pn=92106.00,92113.00,92106.01,92104.01,92133.00,92112.01,92101.101,92101.100,92134.100,92107.0005,92107.0010,92134.200,92107.03,92107.13,92134.400,92138.00,92137.00,92107.00.07,92102.00,92136.010X&cn=WARN+Winch+$80+CASH+BACK+Rebate&c=142&sgsc=QNEWSLET20110725&utm_medium=newsletter&utm_source=20110725&utm_content=header
Title: Re: Internet Deals Thread - 25% off at HarborFreight Jan 1st only
Post by: sharpxmen on January 01, 2012, 03:31:26 PM
(http://images.harborfreight.com/cpi/emails/5211/b/images/nydcoupona_01.jpg)(http://images.harborfreight.com/cpi/emails/5211/b/images/nydcoupona_02.jpg)(http://images.harborfreight.com/cpi/emails/5211/b/images/nydcoupon_03.jpg)
(http://images.harborfreight.com/cpi/emails/5211/b/images/nydcoupon_04.jpg)(http://images.harborfreight22.com/barcode.asp?b=85915520-999999999991010)(http://images.harborfreight.com/cpi/emails/5211/b/images/nydcoupon_06.jpg)
(http://images.harborfreight.com/cpi/emails/5211/b/images/nydcoupon_07.jpg)(http://images.harborfreight.com/cpi/emails/5211/b/images/nydcoupon_08.jpg)(http://images.harborfreight.com/cpi/emails/5211/b/images/nydcoupon_09.jpg)
you can also use it online with the 85915520 cupon code and they have $6.99 flat rate shipping
used it to get a Badland 12,000lbs winch - came to $299 (already on sale for $399)
Post by: Jeffy on January 09, 2012, 10:26:39 PM
Smoking deal.  http://www.jcwhitney.com/off-road-racing-seats/p2011342.jcwx?skuId=353152&filterid=b1604c3380u0j1#CartSnapin
Post by: grumpygy on January 10, 2012, 06:49:47 AM
I would order nothing from them.  They were the ones I was trying to get my seat from and they were on sale like those were.   I ordered and they did not complete the seat Part of the Order.  Then Jacked the Price Back up and said If I wanted them that's the Price I would have to Pay.
Title: FRAM Part # PPA3373 AirHog
Post by: road2damascus on January 17, 2012, 08:18:19 AM
Part Type: Air Filter
* Manufacturer: FRAM
* Part No: PPA3373
Closeout Price:    $9.08
Plus Shipping
http://www.rockauto.com/catalog/raframecatalog.php?parttype=6192&a=RSSW1185207&carcode=1185207
Post by: Jeffy on January 17, 2012, 12:20:29 PM
* Part No: PPA3373
Plus Shipping
That's a good deal for the Airhog.  I have two of those when they were on Amazon and I think I made $2. IIRC.
Post by: road2damascus on January 17, 2012, 06:35:56 PM
I bought two.
Post by: sharpxmen on January 17, 2012, 11:04:08 PM
I bought two.
don't you need an oiling kit for those?
Post by: Jeffy on January 18, 2012, 12:19:52 AM
I don't believe so.  At least not until you clean it.
Post by: jfrabat on January 18, 2012, 06:52:12 AM
IIRC, you dont need oil at all...  I think that was one of the main differences with the K&N.
Post by: sharpxmen on January 18, 2012, 07:42:59 AM
just looked - you need oil, it comes pre-oiled so not the first time you install it but you need a cleaning and oiling kit
http://www.framairhog.com/faq.html
http://www.framairhog.com/cleaning.html
for the money though it's probably cheaper and easier to just buy replacements
Post by: road2damascus on January 18, 2012, 08:10:21 AM
Got K&N air filter cleaner and oil left over from my Supra TT
Post by: jfrabat on January 18, 2012, 07:39:38 PM
I guess I should probably oil mine then...  I have cleaned it out twice and never oiled it.  I wonder where I could get that oil around here...
Post by: FourbangerYJ on March 21, 2012, 09:42:16 AM
https://www.cabelas.com/
$2.00 shipping on any order over $49.00. Good until 3-28-12
I love this place. I wish they had a store close by.
Post by: sharpxmen on April 06, 2012, 12:18:20 PM
Harbor Freight 25% off cupon code 11207016 valid on Sun April 8 2012 or in store if you print this one http://widgets.harborfreight.com/wswidgets/common/displayCoupon.do?week=1412&campaign=b2&page=25off_l.html&single=true&cust=99999999999&keycode=1002
Post by: sharpxmen on May 24, 2012, 12:16:18 PM
just got this in an email from POR15, thought i should share
Free shipping on POR15 orders
Quote
Use code MD2012 and receive FREE Shipping on any Retail order placed from Thursday May 24th 2012 thru Tuesday May 29 2012.  Remember to use code MD2012 on the checkout page to receieve FREE Shipping on your order.
(http://static.scsend.com/files/5013731/MemorialDay2012%281%29.jpg)
Post by: sharpxmen on July 04, 2012, 02:39:30 PM
another free shipping offer from POR15
Quote
Use code JULY4FSO and receive FREE Shipping on any Retail order placed from Tuesday July 3rd thru Monday July 9th 2012.
Post by: aka-justin on October 02, 2012, 08:45:24 AM
$9.00 for some jumper cables. Good deal if you don't have a set.
http://www.summitracing.com/parts/XYZ-AABC06-16/
(http://static.summitracing.com/global/images/prod/large/sum-bbc616_w.jpg)
Brand
Summit Racing Clearance
Manufacturer's Part Number
AABC06-16
Part Type
Jumper Cables
Product Line
American Power Jumper Cables
Summit Racing Part Number
XYZ-AABC06-16
Cable Length (ft)
16.000 ft.
Cable Gauge
6-gauge
Clamp Style
Standard
Clamp Material
Steel
Clamp Finish
Black/Red
Quantity
Sold as a kit.
Post by: jfrabat on October 02, 2012, 01:48:48 PM
Jumper cables are also good for joining 2 batteries to weld while in the field...  Use 2 sets of jumpers, a general purpuse rod, a vise grip (to hold the rod; jumper cables do not do a good job of holding the rod steaty, so it is easier to hold the rod with the vise-grip and conect the jumper to it), connect the netaive lead to the rod (vise-grip), postive to the part, connect one of the batieries positive cable to the other' negative, and weld away!  You can control the amps by the number of batteries you use (1, 2, 3 or more, depending on the thickness you are welding).
Post by: Jeffy on November 08, 2012, 09:39:09 AM
Several good deal on Kobalt tools.  http://slickdeals.net/permadeal/82172/lowes-kobalt-mechanics-tool-sets-w-case-131pc-standardmetric-combo-50-93pc-standardmetric-40-63pc-standard-30-35pc-standardmetric
Post by: Jeffy on November 08, 2012, 10:16:54 AM
Here's another one for Gearwrench
http://slickdeals.net/permadeal/81932/true-value-gearwrench-8pc.-sae-ratcheting-combination-wrench-set-1-for-10-or-3-for
Title: Re: Internet Deals Thread - 12,000lbs winch at $299
Post by: sharpxmen on January 13, 2013, 10:17:41 AM
12,000 lbs winch sale at Harbor Freight $299
http://www.harborfreight.com/Off-Road-Winch-with-Automatic-Load-Holding-Brake-12000-lb-Capacity-68142.html?utm_medium=email&utm_campaign=0213c&utm_source=1012
Post by: vanNiets on January 16, 2013, 04:34:47 PM
Beware JeepAddOns
I just got off the phone with JeepAddOns. I had a horrible experience. It may have earned everyone else a bigger "discount", though, so my loss may be your gain. Let me explain:
I ordered an Engo 9k way back at the beginning of November. Only $275 with an extra $25 for an 8 Ton snatch block? Let's make it an even $300 and be on our way. Oh, there'll be a problem. The winch won't get shipped and to my door until about the 21st of November. Um, okay. It's a good deal, so I'll wait.
And wait. And wait. November 21st came and went. By December 1st, nothing. I tried calling and got nothing for about ten minutes. I'm in a hurry, so I get off the phone. Try again from another phone a couple days later. Nothing. Notice my bank has a cancel on the pre-authorized charge that I allowed. What the hell? Alright, guess I'll find some other winch.
Fast forward to yesterday, when I get a hit on a charge against my old bank card that had been canceled in January. I get online to figure out what happened. Turns out to be JeepAddOns. I've also got an invoice in my email. There's everything. I call my parents, where I use their physical address. Dad found the boxed winch sitting in a covered area to the side of the garage. Shippers put stuff their since my parents live out in the country. They weren't expecting a big box since I told them the order got canceled, so they didn't know to look. I don't even know how long it had been sitting there. It isn't even what I ordered.
So, here I am today, calling to return the winch. I tried yesterday, but I was too busy to wait longer than ten minutes. I call today with more time. Something happens and I get disconnected. Try again. Somebody answers and transfers me. Bob answers the phone. Bob is a nice guy and tries to sort everything out, obviously while on speaker phone. But crap went south real fast when the guy who answered for the transfer jumps into the background and starts doing Bob's work for him. He starts in about how it's my fault because I didn't call to cancel the order. He also says the difference in winch was a free upgrade that I shouldn't worry about. Didn't mention the missing snatch block, of course. he just kept talking over me and mentioning how he's looking at the phone records and can assure me that I didn't call about anything since I talked to Chris back in November. He assures me that I've never been on a hold. He's going on and on and on. I got upset at all the negative in your face b.s. and tell him I'm not doing anymore business with him. I tell him Bob was doing great until he pops in. I also mentioned that I'm going to post this on the different Jeep forums that I'm on. At that point he just speaks over me, as he already doing, and says, "Don't give him a return. Clear it out. He doesn't deserve it. Don't give him a refund. You go ahead and mention it on your forums. I'll just be on there tomorrow to give them a bigger discount. They can thank you for their discount."
Are you freaking kidding me? This is how you treat customers, JeepAddOns?
So, go ahead and enjoy whatever extra discount may or may not come your way. I've already got a very good Warn winch from one of the other Reservist guys I'm deploying to Afghanistan with this year. I'll easily sell this Engo winch for a discount to one of the firefighters I work with in my daily job. I'm on about half a dozen sites like this, and I'll spread my message to all. I'm also spreading the word to all my firefighter contacts (lots of 4X4 owners).
And, while writing this, my Chief Petty Officer, whom I called for advice, gave me some more options: I'm going to make a complaint with the Better Business Bureau, as well as making a notice on our Reserve website. Lots of Navy SeaBees have 4X4s, too. Hell, I'll even spread the word with the Commander of the Reserve Center. I'll tell anybody and everybody I know to stay clear of JeepAddOns. Chris was a nice sales guy, as was Bob in customer service. But it just isn't worth the overall problems to deal with this. Never again.
Post by: sharpxmen on January 16, 2013, 06:50:19 PM
yep, BBB - they will put them out of business if they get too many complaints.
Title: Re: Internet Deals Thread - HF 20% off cupon
Post by: sharpxmen on January 24, 2013, 04:35:49 PM
20% off at harborfreight thru Jan 31
http://widgets.harborfreight.com/wswidgets/common/displayCoupon.do?main=true&week=0413&campaign=b&page=20off.html&single=true&cust=99999999999&keycode=1002
and again the 12,000 lbs winch is on sale at $299 till the end of January
http://r.harborfreight22.com/r2/r4.asp?r=22831_422064&i=Q33360C02H023&utm_source=1002&
