General Forums => The Mess Hall => Topic started by: yikes on November 15, 2009, 01:17:17 PM
Title: Trans Dipstick Problem - Need Your Help
Post by: yikes on November 15, 2009, 01:17:17 PM
My problem: Looks like the 1998 TJ I just bought has the wrong trans dipstick in it. Does any one have a 1997 or 1998 TJ with an automatic trans in it ? ----- that would take some measurements from you trans dipstck ?---- so I can remark or "make" a dipstick for mine ? It has to be a 97 or 98 - I am told by the local dealer. The part number for the one I need is 52118063 or 52104278 AA. But is discontinued . Numbers should be stamped on stick.
Thanks.
Title: Re: Trans Dipstick Problem - Need Your Help
Post by: tjjohn on January 27, 2010, 07:44:45 PM
No but if you need and cant find one you can always get an aftermarket one from locar
Post by: dwtaylorpdx on January 27, 2010, 08:08:50 PM
You still need the factory measurements with the locar.  :stick:
So his question is quite valid, whats the distance from cap to upper and lower fill marks.
Post by: yikes on January 27, 2010, 09:07:04 PM
http://www.jeepsunlimited.com/forums/showthread.php?t=512334
The measurement from the rubber seal to the max line is 25 3/4". From the seal to the min line is 26 1/4". Hope this helps.
