General Forums => The Mess Hall => Topic started by: radark1 on December 03, 2009, 11:04:22 AM
Does anybody know of a replacement bulb for the turn signal indicators in the dash....that are much brighter than the stock ones. I can barely see mine when they are flashing.... and often leave them on unecessarily for long periods of time. LED's perhaps....???
So....I gather by all the response.......I guess nobody else has had this issue with their turn signal indicators. Oh well.
i usually don't look down at the blinker half because i am used to having to unclick the blinker on my s10.. i think they are abit dimmer than most but bright enough to notice.. you could probably brew up your own LED but you could probably need a resistor in there to keep the current low enough so you don't fry the LED. but space may be a bit of an issue unless you can modify the bulb carrier.. which i have yet to find a way to actually disconnect the wires so you can get it out of the jeep. granted mine is a 990 so its tbi and generally different in the electronics department.
My 94 has ANNOYING bright indicators. So nope I don't have the problem.... :smile:
http://www.superbrightleds.com has many replacement bulbs.
I don't really look at my turn signals. I can usually hear that relay ticking. :lol:
Thanks for reminding me about that website....so easy to pull out the dash now that I've done it a couple of times. Planning on picking up some white led's and throwing them back there. :thumbsup:
Once again...the forum pulls through. YEAH! I have sent an e-mail to the website http://www.superbrightleds.com, that DWTAYLORPDX mentioned. Hopefully they will have brighter lights than the stock ones. MANY THANKS! Will keep you all posted on the outcome.
