General Forums => The Mess Hall => Topic started by: czjeeper on December 29, 2009, 07:03:01 PM
Title: Which winch did we get?
Post by: czjeeper on December 29, 2009, 07:03:01 PM
My brother just picked up a '93 YJ.
In the box of parts we got, there was this:
(http://i19.photobucket.com/albums/b183/c_zielsdorf/IMG_1160.jpg)
(http://i19.photobucket.com/albums/b183/c_zielsdorf/IMG_1162.jpg)
(http://i19.photobucket.com/albums/b183/c_zielsdorf/IMG_1163.jpg)
It's a Warn, but what is it?
Obviously we need a cable. Where is the best place to get that?
The roller fairlead is still mounted to the winch plate on the Jeep.
What else do we need?
Thanks!
Title: Re: Which winch did we get?
Post by: aw12345 on December 29, 2009, 07:15:34 PM
Looks like an 8000 lbs winch just make some in cab switches for it and see of it works then buy some cable for it
Post by: Jeffy on December 29, 2009, 08:30:01 PM
I'd wager to guess that is a Warn MX 8000 D1 (http://docs.google.com/viewer?a=v&q=cache%3ApOmqYwJub4AJ%3Awww.warn.com%2Ftruck%2FReplacementParts%2Fparts%2F7%2Fsrrpl115-116.pdf+MX+8000&hl=en&gl=us&sig=AHIEtbSB6ZzVLceiRTrdxuwJCbdvl68dLQ&pli=1).  If it is then it predates the M8000.
You don't really need a controller from Warn which are $$$.  You can either make your own controller and use a generic kit box or you could hardwire it to the dash or console.  For the solenoid box you can get a plastic box that sort of fits and drill holes to screw into the backing plate.  I wouldn't leave them exposed since there is an off chance of you touching them or something arching them as there is no off switch for them.
Post by: dwtaylorpdx on December 29, 2009, 11:07:00 PM
Warn used to have the solenoid controller diagram on their web page.
You can build one out of std solenoids.
Post by: 97 TJ - I dont wave on January 04, 2010, 09:05:36 PM
Your winch appears to be Warn model #25314 Vehicle Winch. This Winch is rated for 8000 lbs.
Post by: Jeffy on January 04, 2010, 09:20:13 PM
That's a Motor PN.
Post by: dwtaylorpdx on January 04, 2010, 09:43:57 PM
Looks exactly like my M8000 if that helps...
