General Forums => The Mess Hall => Topic started by: TahoeYJ on December 30, 2009, 10:16:11 AM
Title: Outboarding shocks... On a YJ
Post by: TahoeYJ on December 30, 2009, 10:16:11 AM
Been following this thread on JF for the past few days
http://www.jeepforum.com/forum/f9/outboarding-rear-shocks-upper-spring-bucket-relocation-929056/
It seems like it'd be much easier to do this on a YJ than a TJ. I lost a lot of up travel when I put my 9" in, and even after adding the MORE rear brackets at the frame I still don't have the same as I did before the swap. I get bored and always want a new project to do on my Heep and this could be fun, and a learning experience. Still kind of skeptical about cutting into the frame... But it appears others haven't had issue?
I'm not necessarily going to to this, but I figured I'd see what yous' guys' think  :doggy:
Title: Re: Outboarding shocks... On a YJ
Post by: chardrc on December 30, 2009, 10:39:42 AM
looks interesting.. only thing with a yj is that your welds for teh new shock tower are going to be more critical since you have half of the load form the leaf springs connecting to the frame behind the shock tower unlike the tjs that have all the load in front of the shock tower.
Post by: Torch_Ind on December 30, 2009, 12:04:37 PM
I really like that guys front fenders
Post by: Jesse-James on December 30, 2009, 03:21:11 PM
Rear in mine is linked with the MORE extensions and raised lower mounts and I have no issue with shock length. Hard to believe you could have an issue with leaf springs.
Post by: aw12345 on December 30, 2009, 05:39:12 PM
The front fenders are rev111 now produced by metal cloak, I believe they are available for a YJ also
Post by: Jeffy on December 30, 2009, 08:38:14 PM
Hmmm, I thought Metal Cloak was the product line and Rev111 was the maker.
Post by: Torch_Ind on December 31, 2009, 10:20:25 AM
thanks to the both of you for the name I found them online. they are very nice!!
Post by: TahoeYJ on December 31, 2009, 12:25:26 PM
The lower mounts are much higher than they were on the D35. From the rear of the Jeep you can't see anything hanging below the axle tubes. I've flexed my junk out on the retaining wall in my dads front yard (mall crawlin' foo  :twofingers:), which is about 22-24", I've still got about 2.5-3" before I rub and the rear shocks have around 1" travel before they're fully compressed. I don't want to go to a shorter shock, so the only other option would be different mounts, mounted slightly lower on the axle tubes...
Post by: Jesse-James on December 31, 2009, 12:34:19 PM
Sounds like a tad shorter shock is the way to go. Again my rear lower mounts are raised as well. Doesn't hurt my flex at all. I'd triangulate them before hacking the frame up. Unless you want to do it "just to do it"
My lower mounts
(http://i68.photobucket.com/albums/i33/jlafaive/misc/05121416.jpg)
..and a flex shot.
(http://i68.photobucket.com/albums/i33/jlafaive/DSC03073.jpg)
Post by: FourbangerYJ on December 31, 2009, 12:41:06 PM
My lower mounts
..and a flex shot.
 :bow: Looks good,
