General Forums => The Mess Hall => Topic started by: bootguy on February 07, 2010, 08:18:29 PM
94YJ 2.5L with automatic transmission. Pulled the air cleaner box and Hose to the throttle body, the Hose was caked with oil and crud. Cleaned it out, then pulled the tube from the PCV valve to the hose it was pretty filthy, so I cleaned it also along with the throttle body. Purchased new PCV valve Rubber Grommet and new air filter, but was told that valves and rings are bad because there is oil in these places. Now the question is fact or fiction? Any thoughts?
Do you mean the CCV? That's the small brass fitting on the valve cover above #1 cylinder that has a hose leading to the intake below the TB. Your '94 does not have a conventional PCV.
This is a PCV valve on the back of the valve cover that goes to the rubber tube between the air cleaner box the throttle body. There is also another tube that goes from the rubber tube to a cannister on the firewall under the master cylinder.
That's a Fresh Air Vent.
Are you getting oil in your air box?
Not in the air box itself, but in the rubber hose going to the throttle body. It is ridged but was smooth inside from gunk filling the ridges. The air cleaner was really crappy, thought that maybe that was pulling oil mist from the engine. (path of least resistance)
you're not "pulling" from the engine, there is no breather so there's no pressure differential other than the blow-by. the only place you are pulling from the valve cover is at idle when your crank gases are going thru the brass fitting above cyl 1 (the one Jeffy mentioned) and going straight into the intake but below the t/b. check the brass fitting and the fitting in the manifold, if those get clogged you get more oil in the airbox and t/b - that's what usually is the case with the Jeeps - in more extreme cases you need to take the valve cover off and give it a thorough cleaning as the gunk can block the output thru that fitting.
There is also a small inline orifice in the tube from the valve cover to the intake below the throttle body. This orifice commonly gets clogged with carbon buildup and causes the crankcase to push oil and crankcase vapors to other places.
Depends on teh year of the 2.5 some are a brass fitting at teh valve cover, some are an line orifice.
But a clogged air cleaner will suck oil the wrong way up the large breather tube and coat the air filter.
he's got a '94 so i think his is in the valve cover (the brass fitting).
there's no breather, everything is behind the air filter so there's no "sucking" thru the crank/valve cover air flow path - not sure if i explained it well enough, i didn't finish my coffee yet so i might not make much sense, but what i'm trying to say is that in case your air filter is clogged and you have a breather in the valve cover then there will be a slight pressure drop behind the air filter which would result in some air going thru the breather and then thru the valve cover to the airbox - not the case with the Jeep, all the hoses are behind the air filter so they would see the same pressure drop - unless it's really clogged in which case would "suck" around the valve cover gasket and grommets but i would think that would lack power big time in that case.
Going to take pictures and post this Friday, because it is all visual to me.
No pictures yet due to the rain and lack of garage/carport. Did put the parts together on the kitchen table. It is the tube from the valve cover (#4 cylinder) to the air cleaner box that is pulling oil and coating the the large diameter rubber hose that takes the air from the air box to the TB. took a while to clean everything, but man what a difference. While cleaning the TB discovered a mass of melted plastic and wires. Hope it is dry in the AM so I can take pictures and figure out what they go to.
Thats what I was pointing out, since the crank case vent and PCV line both hook to the intake system, If the filter plugs it starts pulling vapor the wrong way up the larger breather tube and migrates oil with it which drips down on the filter unless you have a cone filter, then its usually just in the air tube. (Depends on the plumbing...) Its worse if your at wide open throttle, since the vacuume to the PCV is pretty low.
Anyway its been a problem on my 94 since new... I keep the air filter clean and run a wire through the brass fitting every other oil change or so.
I need to clean the tube going to the brass fitting also. But this mass of melted wiring has got me paranoid now that I know it is there.(http://)
Oh also Dave said what I was trying to get across. Thanks.
Is there a spray for this, or pull it out and run a wire though it?
I used a pipe cleaner and some carb cleaner.
It is threaded in so you can remove it and spray it out.
