General Forums => The Mess Hall => Topic started by: AC3tj on March 29, 2010, 05:06:25 PM
Title: regear ?'s
Post by: AC3tj on March 29, 2010, 05:06:25 PM
ok so i have been thinking about regearing my axels and would like your oppinions on it.
i have a 97 tj with a i4 and 33in tires what gears should i go with( this is my daily driver as well as toy).
also how much did you guys pay for similar replacements.
Title: Re: regear ?'s
Post by: jfrabat on March 29, 2010, 05:14:07 PM
Manual or AT?  Assuming Manual, 4.88.  Dont remember how much I paid, though, but it was not cheap...
Post by: AC3tj on March 29, 2010, 05:17:38 PM
oh yeah i forgot to say it is manual trans
 4.88s seem to be the answer for everything!?
Post by: aw12345 on March 29, 2010, 05:23:57 PM
It's not the answer for everything, but works pretty darn well
Post by: jfrabat on March 29, 2010, 05:48:01 PM
Actually, I would recommend 5.13's, but that means two new D44's.  So 4.88 is the best you can do (that's what I run on my YJ, and works out good).
Post by: FourbangerYJ on March 29, 2010, 05:54:52 PM
Around here for parts and labor your looking at the $1200 range for front and rear to be regeared. YMMV.
Post by: Jeffy on March 29, 2010, 06:06:07 PM
With stock axles, you're limited to 4.88's so unless you want to do an axle swap 4.88's is probably your best answer.
Post by: AC3tj on March 29, 2010, 06:16:30 PM
how much did you guys pay to regear
Post by: Jeffy on March 29, 2010, 06:20:41 PM
It will vary.  If you go to a 4x4 shop, $1200-1600 is about normal.  Check with a speed shop that deals with race cars and they might be able to do it for much less.  Pull your axles and bring them in might even be cheaper as it does not require a rack.
Parts alone with probably be around $400-500.  Labor can be as low as $150-200 an axle.
Post by: Jesse-James on March 29, 2010, 06:47:50 PM
$350
Though I only had to gear one axle and learned to set them myself.
Post by: Torch_Ind on March 30, 2010, 07:01:50 PM
I did my own as well.
so was only the price of the gears and master install kit so I could get bearings and every thing.
Post by: bumati on April 01, 2010, 06:07:56 PM
I'm a little curious to all you who did this yourself how hard was it to regear?  Everbody i talked to says there's no way you should check this yourself.
Post by: Jeffy on April 01, 2010, 06:19:14 PM
If you're used to wrenching on your own vehicles then it's not too big of a deal.  I mean , I know people who have rebuilt engines in their garages.  Gears can be a bit more frustrating as you are dealing with pinion depth as well as carrier alignment all the while watching your backlash.  It will require some tools that not everyone owns though like a in-lbs torque wrench. Beam or dial.  You can't use a clicker.  Hydraulic press and maybe a bearing puller would also be required. You can get away without a dial indicator but really, if it's your first time, then you'll probably want one as well.
It does come down to the saying, "If you have to ask then...".
