General Forums => The Mess Hall => Topic started by: bammerman on March 30, 2010, 09:45:17 AM
Title: coolest top in world (saw JJ had it)
Post by: bammerman on March 30, 2010, 09:45:17 AM
Safari BikiniŽ tops for Jeep Wrangler, 92-95
http://www.bestop.com/index.php?s=8
(http://www.bestop.com/images/products/thumbnails/52529-09.jpg)
It says 92-95, what is the difference in the body as to why a 90 won't work.  I am willing to redo my rollbars, modify the top, etc... to make this fit on my jeep.  just need some ideas as to why it doesn't work currently
Title: Re: coolest top in world (saw JJ had it)
Post by: sharpxmen on March 30, 2010, 09:49:13 AM
i think the roll bar is different on yours
Post by: jfrabat on March 30, 2010, 10:17:09 AM
Two things; first off, the safary top does NOT include the cover of the cargo space.  Second, i think what you are looking for is the haft top...
(http://www.tellico4x4.com/images/products/outland/outland-993017.jpg)
The half top is enclosed and the safary top is open...
Post by: bammerman on March 30, 2010, 10:19:22 AM
That is one I wouldn't mind, too bad when I look it up it says it is for Jeep Wrangler TJ 1997-04 :(
I have a 90 YJ
Post by: bammerman on March 30, 2010, 10:30:00 AM
I think I may be wrong.  I went to JCwhitney and got this for my model
http://www.jcwhitney.com/cab-top-and-tonneau-combination/p2002742.jcwx
(http://www.jcwhitney.com/jcwhitney/product/images/large/G_12742G_CL_1.jpg)
Post by: jfrabat on March 30, 2010, 10:56:19 AM
Half tops ARE available for '91s...  Google it up, and you will find it.  Or go directly to the bestop site.
Post by: bammerman on March 30, 2010, 11:34:08 AM
You were right Jfrabat, I think I have to modify my seats though because the back of the headrest is behind the roll bar so it would press on the top.
Post by: TrailsLessTaken on March 30, 2010, 01:14:25 PM
I have a sealed half top, its not the Bestop brand but you dont have to modify anything to make it work
Post by: bammerman on March 30, 2010, 02:29:33 PM
Oh that is great to hear, will order the top today. Does it snow in your area and if so how does it hold up?
Can you send me a link to the one you own?
Post by: jfrabat on March 30, 2010, 03:04:22 PM
Him being from Indiana, I would guess it does snow a bit...
Post by: bammerman on March 30, 2010, 03:18:51 PM
but he may not use it in winter, never know.  Just trying to get all the info before I purchase.  Better to be safe than sorry.
Post by: Jesse-James on March 30, 2010, 06:04:24 PM
Worst parts about the bestop halftop are the seal at the bottom of the back window will leak. I could not find a way around it nor did it really bother me much. Also the screen is on the outside of the back window and collects water when it's warm out so you cant see, and collects snow and ice when it's cold out so you can't see. Other than that I loved it. It was rally nice to be able to roll the top part up behind the front seats and use it as a tonneau and the flip top was great in spring and fall.
Post by: YJmechanic on March 30, 2010, 08:18:28 PM
i like the look and i run the bikini toneau and windjammer in the summer but i have seen the half tops and the only thing i dont like is that when i do it i leave the frame folded up under the tonneau and it holds tight and sits much higher.  when i saw the half tops it was low to the tub and seemed like there wasnt much tension so i dont know if i ould like it.  can you leave the frame in there?  any pics of anybody whos got them installed on a yj?
Post by: TrailsLessTaken on March 30, 2010, 08:37:24 PM
My jeep is a 91 with the half cage not the full like the 92-95.  The top uses the soft top hardware for the front half like normal to make the door frames and then the rear arms and tension bars just push all the way forward  against the back of the door frames.
(http://lh4.ggpht.com/_6roifxYIFVU/SyhjC_S4AjI/AAAAAAAABBo/jQvCRw6okXk/s800/IMG_0021.JPG)
This is the best side profile one I have at the moment, I will take some better ones tomorrow when its light out
The rear tonneau part pulled decently tight when it was new but after being outside and heating and cooling with the weather it has stretched some and with the snow and rain sitting on it has also helped stretch it.  I took some fiberglass rods that are about an inch wide and maybe an 1/8th in thick, from some of the temporary men working signs i had that you use to hold the sign open and drilled the rivet out and spread it across the back area to keep the top  arched up so the water ran off instead of pooling in the center
(http://lh3.ggpht.com/_6roifxYIFVU/SxSRwg3QeFI/AAAAAAAAAfo/HXcNgCfy960/s800/IMG_0105.JPG)
Post by: TrailsLessTaken on March 30, 2010, 08:39:02 PM
It has sat outside all winter long in the rain and snow and I didnt have any moisture what so ever inside the cab that I ever found
Edit:
The top is made by Rampage I believe it was, I believe the picture that Felipe posted is the one by the same company for the 92-95 jeeps.  I got mine from windrock offroad but I dont see it on the site anymore but found one like it here on telico 4x4 for $184 which is what i think i paid for mine
http://www.tellico4x4.com/index.php/cPath/86_2012_2908 (http://www.tellico4x4.com/index.php/cPath/86_2012_2908)
Post by: bammerman on March 31, 2010, 04:17:30 PM
I ordered one yesterday, 175 with shipping from JCwhittney, not bad.
Post by: YJmechanic on March 31, 2010, 07:22:24 PM
[/quote]
this what i mean see how thick the top section is and then the tonneau just looks flat and thin,  if you can imagine what the softtop frame width is folded,  that is how high my tonneau sits.  that way the top and tonneau are about the same thickness,  if you get what i mean  ( back of top is like 6 inches thick and then the tonneauu is only like one inch from flush to the body,  just looks odd to me)
Post by: TrailsLessTaken on March 31, 2010, 08:54:45 PM
Thats how my other half top is that isnt sealed, I normally dont wheel with this one on so it doesnt get messed up but with it being winter I was to lazy to change it out.  It took me a little while to get used to this one not being as tall as the other
