General Forums => The Mess Hall => Topic started by: neale_rs on April 30, 2010, 03:49:19 PM
Title: MTS 0065 gas tank question
Post by: neale_rs on April 30, 2010, 03:49:19 PM
I have an MTS 0065 gas tank for the YJ.  I bought it to use it with a Kilby gas tank skid plate but it did not fit so I ended up repairing the original gas tank.  I recently got a gas tank cap that actually holds pressure and now my repair is leaking (I'm running with the gas cap really loose for now). So my question is:  Does anyone know firsthand of a heavy duty skid plate that will work with the MTS 0065 gas tank?
Thanks
Title: Re: MTS 0065 gas tank question
Post by: FourbangerYJ on April 30, 2010, 05:06:17 PM
Never heard of it. Got a link?
Post by: neale_rs on May 01, 2010, 10:51:07 AM
Here is a link:
http://www.mtscompany.com/jeep.htm
4WD Hardware is also selling it now.  It may be the only aftermarket poly 20 gallon YJ tank available (Gen Right has aluminum tanks).  I'm looking into getting a used stock tank but it might cost about the same to get another skid plate that works with the MTS.
Post by: aw12345 on May 01, 2010, 10:54:08 AM
Looks a lot like a TJ tank maybe you could get an old TJ skid and see if you can make that fit.
Post by: neale_rs on May 01, 2010, 10:59:04 AM
The bottom angles are different so it won't fit in a snug fitting skid plate although it fits fine in a stock skid.
Thanks for the offer but I think it would be pretty hard for me to make it work.
Post by: neale_rs on May 01, 2010, 08:44:15 PM
Well, I won a stock YJ tank on eBay for $112 so it wasn't too bad, much cheaper than a new skid.  Now I just have to get it down here and install it.
Thanks
Post by: neale_rs on May 06, 2010, 07:35:33 AM
Thanks.  Actually it seems these tanks are fairly easy to find on eBay.  For example, there was one "buy it now" for $100 plus $30 shipping as well as another two at auction.
Post by: neale_rs on May 06, 2010, 04:39:58 PM
Some additional information (not personally tested):  justgastanks.com told me in an email that the 0065 MTS tank fits in the Rugged Ridge (Omix Ada) heavy duty diff.  They said a customer of theirs bought both and it worked.
Post by: neale_rs on May 18, 2010, 08:10:34 AM
Just an update:
Got the eBay tank installed, no leaks so far, but it does not pressurize.  The Jeep runs fine though.   I guess I'll wait to see if any gas leaks out next time the Jeep gets tilted on a trail and then look into getting new hoses, breather valves, valve seats, gaskets, etc.  This just goes on and on!  :brick:
Post by: sharpxmen on May 18, 2010, 08:19:53 AM
Just an update:
what do you mean it won't pressurize? i think it would always release in the evap canister (from what i understand)
Post by: neale_rs on May 18, 2010, 09:01:07 AM
Maybe I should learn more about this.
When I put a new gas cap on the old tank, it would pressurize.  When the gas cap started being removed I could hear gas escaping, I figured this was the normal behavior.  Now, with the new tank, when I remove the gas cap, no sound is heard.
So that pressurization with the old tank was not normal?
Post by: sharpxmen on May 18, 2010, 11:16:52 AM
i never heard gas escaping from the tank. I know the cap has a one way valve, and is meant to not release vapors thru there, I always thought that's how the evap canister would work - now that you mention it could be that I am wrong and should pressurize and release when the engine is running - so don't take my word for it, maybe mine was not working properly.
Post by: neale_rs on May 18, 2010, 11:41:42 AM
I checked a bit on the internet and it seems it can pressurize a bit but not as much as I was seeing because as you said, it should vent to the charcoal canister. It seems excess pressure can be caused by a pinched hose from the tank to the charcoal can or by a clogged charcoal can.
Maybe I could have just fixed that and avoided buying another tank.  On the other hand, the previous tank was repaired and probably would have leaked eventually.
