		General Forums => The Mess Hall => Topic started by: melbill on June 24, 2010, 02:32:45 PM
				I just got a new all aluminum radiator for my YJ. I have a manual and when the radiator arrived it is for an auto. Should I plug the holes for the transmission lines, or can I use then as an oil cooler, run a bypass off by bottom radiator hose and get the coolant cooled further, or is there something else I can do to utilize this?
Thanks a lot,
Bill
Thanks a lot,
Bill
you don't need to plug them, they are connected to an internal tube and it is separated from the water circuit (what i mean is that coolant will not come out thru those holes, they are meant for the transmission fluid).
				They are usually plugged anyway.
				You could use it to cool your power steering.  That's what I plan to do with mine (not yet installed).
				Thank you all for your quick replies. I had not thought about about running power steering fluid through it. Am I right in figuring that I would just adapt the low pressure line into the radiator then a line out into the pump? Also would I have to make the fluid run in one direction or the other (I don't know which way stock is but I am sure I can find it).
Thanks again,
Bill
				Yes, low pressure.  You wouldn't want to run high-pressure though there.  I don't think it would matter which way you go but it would probably be better to keep the hot side short.
