General Forums => The Mess Hall => Topic started by: tracker975 on August 16, 2010, 12:38:14 PM
Title: Trannie leak
Post by: tracker975 on August 16, 2010, 12:38:14 PM
I have a 95 yj with a 4cyl automatic trannie....It has a pretty good leak between the T/C and the trannie and I need to address it as soon as I can.My wife doesn't appreciate the change in color of the driveway :yikes:.The Chilton manual i have isn't exactly a big help and I need all the help I can get.I have the wrenching skills just above a chimp.Is this just a straight forward removal or are there some little things I should know...I was also thinking of having my trans rebuilt..it seems a bit tired and doesn't like to climb the steeper roads around here..it has 180,000 on it...Should i just pull it out as one and seperate it on the bench....anything special I should ask for when getting the trans done..IE: shift kit..well thats all i can think of lol....thanks in advance for your time and help :beers:...Joey
Title: Re: Trannie leak
Post by: sharpxmen on August 16, 2010, 01:14:06 PM
not an expert on autos but as far as removing them i suggest first to drain both fluids out, remove them separate and not together. the t-case drain plug is not the one on the underside (from what i remember) it is on the other side of the output shaft (the one on the underside is the chain tensioner i think). there are a few guys here that have auto transmission so hopefully they'll jump in with some information/tips/tricks.
Post by: Bounty Hunter on August 16, 2010, 04:11:09 PM
Remove the driveshafts, transfer case linkage, and the 6 nuts attaching the transfer case to the transmission.  Remove the transfer case and replace the transmission output seal.  That should be it.
Post by: tracker975 on August 16, 2010, 06:44:43 PM
Great thanks for the help... :beers:..I am gonna get to it here in the next couple days...I will let ya know how many screw ups I have and how it comes out...again thanks for the help..Joey
Post by: tracker975 on August 19, 2010, 12:37:53 PM
I have everything off and I am ready to drop the T/C...now for one of my chimp like questions...when i seperate the T/C from the automatic trannie to change the trans output shaft seal do I take out the bolts in front of the mount or behind the mount :confused:....The book I have is of absolutely no help at all....Thanks Joey
Post by: sharpxmen on August 19, 2010, 12:49:41 PM
hmm  ??? , the t-case is mated to the tranny with nuts on the studs that are in the t-case - so if you're seeing bolts those are part of the transmission, you don't want to take that apart. Now questions is where do you see the leak? if it's where the bolts are (and not the t-case nuts) then your leak is not at the tranny output shaft. Take some pics so we can see what's going on there.
Post by: tracker975 on August 19, 2010, 02:02:09 PM
OK I gotcha thanks...The leak is right by the nuts....the fluid is coming out right on that seam...so take the 6 nuts off and slide the T/C back and the seal is right there?.....is there also a seal on the T/C side as well or just on the trannie side...sorry I never did this before and I am running solo so I need and will take all the help I can get...unfortunately pics aren't an option for me right now..I can try to get pics up later....thanks Joey
Post by: sharpxmen on August 19, 2010, 02:19:55 PM
there's a seal on the tranny side but in your case i don't know if it seals on the output shaft or on the input shaft of the t-case (that's how the AX-5 manual is setup), doesn't really matter anyway - there is also a t-case seal that is on the input shaft.
Post by: tracker975 on August 19, 2010, 06:00:28 PM
I had to take care of some hunny do crap for my wife so I will be seperating them tomorrow....should I go ahead and replace all those seals while I have it open or does that entail more tearing down.If that is the case I think I best be happy I got this far lol....Thanks for the help sharpx it is very much appreciated...I hope I can return the favor sometime....thanks  :beers:...Joey
LOL...bet this is the longest seal swap in history  :roflol:
Post by: Bounty Hunter on August 19, 2010, 07:39:37 PM
It's likely the output seal of the tranny, it seals tightly around the transfer case input shaft once the transfer case is installed.  I highly doubt it's the seal on the transfer case input, they rarely go bad.
Here's what the back of the transmission will look like once you remove the transfer case.  The seal is around the output shaft.
(http://i209.photobucket.com/albums/bb134/strangedoc/AX5%20Output%20Shaft%20Seal/AX5WeepHole.jpg)
Post by: tracker975 on August 19, 2010, 07:40:55 PM
OK...here goes chimp question number 2....how the heck does that linkage come out...Joey
Post by: Bounty Hunter on August 19, 2010, 07:41:38 PM
This is what the 6 nuts look like you need to remove to separate the transfer case from the tranny.
(http://i209.photobucket.com/albums/bb134/strangedoc/AX5%20Output%20Shaft%20Seal/WeepHole.jpg)
Post by: tracker975 on August 19, 2010, 07:47:39 PM
Hey great pics thanks alot.....wish I could get you all a beer for the trouble I have been...and to top it all off I am doing this with a seperated shoulder and a broken finger lol.
Post by: Bounty Hunter on August 19, 2010, 07:48:03 PM
Transfer case linkage?  Simply remove the 9/16" nut where it attaches to the transfer case, then pull the bar section of linkage off the transfer case.
Post by: tracker975 on August 19, 2010, 07:58:08 PM
I tried that and it is stuck pretty good.....thought maybe there was another way...well hoping lol...gotta go soak it again...PB Blaster rules....I really appreciate the help..this is my first time doing this...I am ok with the everyday basic stuff but when it comes to the heavy stuff I usually farm it out...but I said screw it I can do this lol....thanks Joey
Post by: Bounty Hunter on August 19, 2010, 08:11:24 PM
You can do it, and don't worry about the questions, no question is too dumb.  Place a screwdriver or small prybar behind the flat bar section of linkage and work it off the transfer case.  Once the nut is off, it's only a slip fit onto the shaft.
Post by: tracker975 on August 19, 2010, 08:17:56 PM
OK....gotcha...Thanks again Joey
Post by: Jeffy on August 19, 2010, 08:41:07 PM
Just consider a better topic name...  Trannie isn't what you might think it means.  :whistle:
Post by: tracker975 on August 19, 2010, 08:50:48 PM
LOL..your right....but at least I was close...it is leaking trannie fluid....
Post by: tracker975 on August 21, 2010, 12:06:08 PM
Well...I got the old seal out and the new one in....I just hope I didn't booger the new seal putting the T/C case back in :yikes:....on my back...by myself...with a seperated shoulder and a broken finger lol....had to do a bit of wiggling..not much but it took a few wiggles to get it lined up..then it just slid right in...the old seal was hard as a brick and fell apart when I took it out lol.....I'll let ya know later..........Thanks Joey
Post by: sharpxmen on August 21, 2010, 06:49:53 PM
jeffy meant it's tranny and not trannie
Post by: tracker975 on August 21, 2010, 07:27:56 PM
LOLOLOLOLOLOLOL.........holy crap  :yikes:I can't stop laughing...I just got it....I will be more careful in the future..crap thats funny...Joey
Post by: Jeffy on August 21, 2010, 07:42:22 PM
Personally, I'd rather call it a Trans or Transmission...
Post by: tracker975 on August 21, 2010, 08:08:17 PM
Make no mistake about it I will definitely change my nomenclature lol....Trans it is...Joey
Post by: Jeffy on August 21, 2010, 09:46:31 PM
Yeah, 'Trannie leak' sounds pretty bad...
Post by: sharpxmen on August 21, 2010, 10:14:06 PM
probably increased the hits on the website :lol:
