General Forums => The Mess Hall => Topic started by: knotts89 on November 15, 2010, 09:33:31 AM
Title: lift finally
Post by: knotts89 on November 15, 2010, 09:33:31 AM
went ahead and ordered a zone lift last week. I figured since its my dd and i mostly just do trail rides i wouldnt spend a ton on a lift. we put it on saturday and so far it has been great and the jeep looks a lot better any suggestions on quick disconnects or are they all pretty much the same
Title: Re: lift finally
Post by: aka-justin on November 15, 2010, 06:17:45 PM
I'm not running a sway bar anymore on my 1995 yj.
Post by: Jeffy on November 15, 2010, 06:27:03 PM
I run some Rubicon Express disconnects because they were cheap.
Oh and if you haven't done it already, remove the rear track-bar.  You might consider removing the front but test it out and see if you like it before junking it all together.  The suspension should be a lot softer with the trackbars removed, even if it's just the rear one.
Post by: smashcoast on November 15, 2010, 08:31:40 PM
Better yet scrap those leafs for some coils! ;)
Post by: knotts89 on November 16, 2010, 08:19:45 AM
should have specified its a 98 tj, could i still remove the rear track bar? Zone had a set of quick disco for $100, is that a fair price?
Post by: neale_rs on November 16, 2010, 08:51:08 AM
Don't remove your track bars (TJs need them)!  I'm pretty sure the Rubicon Express discos are cheaper.
Post by: knotts89 on November 17, 2010, 07:30:15 AM
ok thanks for the advice i hope to get some pics up soon, it was a good experience putting the lift on myself i learned a good bit and enjoyed doing it but next time i will make sure i have some better drill dits
Post by: Jeffy on November 17, 2010, 01:12:58 PM
Whoops, yeah, I got thrown by 1995yj's post.
You'll want to keep your track bars and your swaybars.
RE's are the cheapest out there but they may or may not make some noise.  I never had any problems with them.  I also went with them since on a YJ you can drive without the swaybars and I didn't want to soend a lot on something that I might just remove.  I do like JKS's but they cost a lot more.
Post by: aka-justin on November 17, 2010, 01:54:37 PM
*thump* *thump*  Thrown under the bus ;P
Post by: dwtaylorpdx on November 20, 2010, 05:51:36 PM
On my YJ the trac bars are gone, but I run the swaybar most of the time,
because it helps keep the thing going straight when breaking hard...
Without it the jeep tends to pull to the right...
Post by: knotts89 on November 23, 2010, 06:54:15 AM
yea it wont to bad wish i would have had some better drill bits though. seems to have a bit of a death wobbel now around 50 mph but i think it is wear my tires are worn funny so their next on the list
