General Forums => The Mess Hall => Topic started by: BatesOffroad on November 27, 2010, 04:32:34 PM
Title: 97 TJ fuel cell question
Post by: BatesOffroad on November 27, 2010, 04:32:34 PM
Ok I've got a 97 TJ my plans are stretch the rear axle back 5".  So I need to replace the fuel tank and there is no way I'm gonna spend $1000 to do that. I just want to buy a fuel cell and pump. But what pump should I buy to get the correct fuel pressure?
Title: Re: 97 TJ fuel cell question
Post by: Jeffy on November 27, 2010, 06:09:52 PM
Generic fuel cell, RCI 2161A.  Cut your own hole for the sender/pick-up.
(http://static.summitracing.com/global/images/prod/large/rci-2161a.jpg)
http://www.4x4wire.com/jeep/tech/fuel/cellandpickups/
(http://www.maclaughlinstudios.com/Website/images/DSC05256.jpg)
http://www.pirate4x4.com/forum/showthread.php?t=396020
http://www.greatlakes4x4.com/showthread.php?t=190211
http://www.genright.com/ProductInfo.aspx?productid=APR1000
(http://www.genright.com/images/products/APR1000_MULTI_md.jpg)
Post by: aw12345 on November 28, 2010, 12:28:04 AM
That ring works well, my buddy used in on the stretch tank he made himself, darn thing is expensive though, Gen Right wants over 200 bones for it
Post by: BatesOffroad on November 28, 2010, 09:16:10 AM
I dont know why I never thought of that I serched all day yesterday for ideas. I even seen the threaded ring on genrights site! :puzzled: I think thats what I'll do those street rod cells look like they fit perfect.
Thanks for the info guys!
Post by: Jeffy on November 28, 2010, 12:35:35 PM
If you don't have a back seat and want more fuel there is a 30x12x12 that's 19Gallons.
I think there are a few guy's on Pirate4x4 who make different TJ rings.
Post by: BatesOffroad on November 28, 2010, 01:34:01 PM
Yeah I tossed the back seat long ago.. coudnt fit my cooler in there :wine: I did some 1ton build searchng on pirate and found a guy who does them up i didnt pm him yet to see how much though! I post it up when i find out for sure.
Post by: dwtaylorpdx on November 29, 2010, 08:48:44 PM
What makes the TJ setup special? Seems like its cheaper to buy another pump and just use through fitting mounts.
Is the TJ fuel pressure same as a YJ?
Post by: Jeffy on November 29, 2010, 08:54:58 PM
That's what I'd do.  No need for the stupid all-in-one sender.
Post by: dwtaylorpdx on November 29, 2010, 08:59:40 PM
I believe RCI has a solid state fuel guage thats adjustable as well.
Just goes through a vent bug in the tank.
Post by: Jeffy on November 29, 2010, 09:49:32 PM
Yup, comes with one but the sender won't work with the Jeeps.  You'd need a new sender or gauge.
Post by: sharpxmen on November 29, 2010, 11:39:49 PM
TJ has the FPR integrated and is 49psi, YJ has the FPR on the injector rail and sits at 39psi.
Post by: Jeffy on November 30, 2010, 12:32:57 PM
It would be pretty simple to add an inline FPR though.  You would also need to add a fuel filter IIRC.
Post by: sharpxmen on November 30, 2010, 12:47:30 PM
yep, that should be simple if you go with a custom thank, you need a return back in the tank that's all.
