General Forums => The Mess Hall => Topic started by: karan on February 21, 2011, 10:01:28 AM
Title: 62 mm TB swap help needed
Post by: karan on February 21, 2011, 10:01:28 AM
Hi Family,
Today i started to swap the bored out TB.i had a positive attitude, 62 mm TB ,10 mm
socket, a screw driver and a 20 mm torx bit. and now i am a dumb jeeper with two dumber questions
how to take these two off
1)the throttle cable
2)the air intake tubing
Title: Re: 62 mm TB swap help needed
Post by: DOTSON53 on February 21, 2011, 10:12:35 AM
The throttle cable should pop off with a screw driver. If its the cruise control it will slide out. The intake will have a hose clamp around the throttle body.You might also want to buy a repair manual from autozone or napa they come in handy.
Post by: karan on February 21, 2011, 03:49:26 PM
Thanks Dotson53:)
Family,
i finally swapped it.  i cant believe i did it myself that too on the parking lot of my apartment building.
Now, my experience of 3 km of driving is::
jeeps very responsive now
i also feel it runs smoother
i could say i can notice some power gains.
i will drive on highway tonight and post my experience.
Problem: check engine light is on, although the rpm settled back to 800 rpm range at idle.
what to do with the check engine light now? please help.
Post by: jfrabat on February 21, 2011, 03:59:12 PM
You can simply disconnect the battery for about 5 minutes, and it will go away (if it comes back, it's because you really do have a problem, so check the connections to all the sensores, and make sure there are no accidentally disconnected vacuum lines).
Post by: chardrc on February 21, 2011, 04:02:35 PM
you can also check the code by fallowing the procedure in the link
http://4bangerjp.com/forums/index.php/topic,3419.0.html
 post the code and someone will interpret what it means... also do the computer reset like jfrabat suggested
Post by: karan on February 21, 2011, 04:32:18 PM
thanks guys,i will do it, just to add, i did disconnect the -ve battery terminal before starting the procedure and only connected after
i was done tightening the last screw.
Post by: karan on February 21, 2011, 05:54:35 PM
Ok now, i disconnected the battery -ve terminal for more than 5 minutes, reconnected started the jeep, check engine light on again.
i also took the jeep for a highway ride.
Issues noticed::
Jeep tries to die when i tried to accelerate fast.
like from a street with 45 m/h merging to a street with 65 m/h, the jeep dies/hesitates and after a couple of hiccups it gains desired speed.
its happening all the time on accelerating fast
check engine light is still on.
* The Throttle position sensor was jammed on my 2.5 body, one screw wont open, so i had to take that to the mechanic who some how
managed to take that out after doing everything {small hammering included}
coujld that be the culprit, i mean could the TPS be gone?
what else could be wrong.
I will look for the error codes now.
Post by: sharpxmen on February 21, 2011, 06:37:50 PM
what year Jeep do you have?
Post by: karan on February 21, 2011, 06:56:21 PM
Its a 2000 Jeep TJ 2.5
Post by: karan on February 21, 2011, 08:41:47 PM
Ok so i googled and did 3 hours of research on internet, and every place i found the same info
a defective TPS seems to be the reason, all the indications and side effects that i am experiencing
match with the defective TPS behavior.
Now i want to know would it be ok to keep driving like this for 2-3 days before changing the TPS or shall i not touch my jeep till i
change the TPS? i dont mind the defective TPS for 1-2 days as long as i can drive my jeep and it doesnt hurt my jeep in anyway.
Thanks again to every body helping me out
Post by: sharpxmen on February 21, 2011, 08:42:55 PM
make sure that little rubber elbow for the MAP sensor on the t/b is not cracked or plugged.
What do the codes say?
Post by: sharpxmen on February 21, 2011, 08:44:08 PM
it is very likely to be the TPS but doesn't hurt to get the codes, if it's the TPS that's the code you'll get and then you know for sure.
Post by: karan on February 21, 2011, 10:23:12 PM
Thanks Sharpxmen, i checked the rubber elbow as you instructed, its good.
i did the code test, i dont think i got it right, i tried several times.
codes started with all 0000000s then went through all 11111s to 99999s
each time same thing, with all light goin on off and meters dancing.
after going from 0000000s all the way sequentially to 99999999s, it showed the odometer reading and kept showing it.
then i just appl;ied my own stupid formula and checked what series shows the check engine light on
that is:: 333333333 444444444 55555555 66666666 88888888
on 00000000 11111111 22222222 77777777 99999999 check engine light was off.
i dont think its helpful!
Post by: Bounty Hunter on February 22, 2011, 09:27:21 AM
Sounds like a bad TPS.
As for checking your own codes, the 0000000 11111111 etc. is the gauge cluster cycling through a diagnostic test and has nothing to do with trouble codes.  If you get this, you released the odometer reset button too soon, or your model jeep doesn't display diagnostic codes using the self-test.
Try this:
Key off.
Push and hold the odometer reset button.
Turn key to run (not start).
Turn key off.
Release odometer reset button.
Trouble codes should display in the odometer window.
Post by: karan on February 22, 2011, 12:11:56 PM
Try this:
Key off.
Turn key off.
Thanks Bounty Hunter, i followed the steps and all that gets displayed doing your steps is
2.5
after displaying 2.5 nothing else is displayed, i waited and tried the same procedure many times but always 2.5 is displayed.
what would that mean?
Post by: karan on February 22, 2011, 01:50:55 PM
Family,
So i didnt go to work today since my jeep was sick :)
error codes didnt reveal anything.
so i went ahead and bought a new TPS, just finished installing.
check engine light went off, no hiccups :)
its snowing here n i live in downtown calgary so couldnt drive fast, but upto 35 m/h and fast acceleration showed
no hiccups or any thing like that, jeep ran well.
I thank you all from the bottom of my heart to come and help me in the hour of need.
2000 Jeep TJ 2.5
62mm TB, 62 mm TBS, Dynomax Catback.
awaiting jet stage 1 and firepower kit
Post by: Jeffy on February 22, 2011, 02:14:24 PM
You might disconnect the plug and reconnect it.
Post by: Bounty Hunter on February 22, 2011, 08:44:24 PM
2.5
Code 25-Automatic Idle Speed (AIS) motor driver circuit-short or open detected in 1 or more of the AIS control circuits.
Post by: karan on February 22, 2011, 09:50:24 PM
BH,
thanks for the code help.
Family,
Although the jeep runs fine after changing the TPS, no hiccups, but i did notice some thing when i opened everything up today to replace the faulty TPS.
I noticed engine oil on the walls of new throttle body spacer, it wasnt dripping or anything but yes oil was there and i could touch and see the oil on my fingers.
Important to mention i had only driven the jeep for close to 30 kms yesterday after installing the throttle body and throttle body spacer.
jeep was parked for more than 17 hours before i opened and saw the oil there.
is it fine or do i need to do something??
P.S. check engine light is off now after changing the TPS, which is good.
Post by: Bounty Hunter on February 23, 2011, 03:57:44 PM
I'd wipe it off and keep an eye on it, doesn't sound serious.
Post by: karan on February 24, 2011, 08:08:31 AM
Thanks BH, do you think the gasket could be causing it, i had one new gasket that i used between TB and TB spacer and i reused the old gasket between TB spacer and the
Intake. that wasnt torn but wasnt in the best condition either. could the worn out old gasket cause any issues??
Post by: sharpxmen on February 24, 2011, 09:31:12 AM
your idle would be high if there was a leak at the t/b gasket
Post by: karan on February 24, 2011, 09:53:45 AM
Idle is actually fine, just at 800 as it was before, so i guess i wont worry about it then, thanks sharpxmen!
Post by: Bounty Hunter on February 24, 2011, 04:00:56 PM
I put a small amount of oil in the throttle shaft bearings, that's the only place I can imagine your oil came from.  That's why I recommended cleaning it off and keeping an eye on it.
Post by: karan on February 24, 2011, 07:01:55 PM
Thanks BH, I hope it came from there, I will wipe and keep an eye on it and will update
if i see it again.
* To those who are wondering how BH can put oil in my TB throttle shaft bearing-The TB and TB Spacer i put on was bought from him.
