General Forums => The Mess Hall => Topic started by: RT on February 21, 2011, 11:04:52 PM
Should I get the good stuff (royal purple, redline, valvoline) or just get the $4 crap at autozone......plus what's the better weight 80-90 or 75/85-140. I'm in New Mexico so temperature's not an issue for lubrication.
cheep I would pick if your in high heat area.. at the most pick the cheapest synthetic blend
Well, I've been having a lot of drivetrain whine.....probably just a jeep thing but idk...the diff fluids grey so I'm going to see if that's it. What would shut it up better, synthetic or mineral?
chances are if it's water or debris in the fluid "making it gray" it may make a difference in noise just putting in anything clean.. it's that or you have a bearing going or ring and pinion whine !!
They're was some nasty sh*t in there! lol, it was weird, there weren't any 'shavings' but the oil was 'glossy' and shiny. I ended up putting $4 80-90 and lucas stabilizer in it and it actually drives better. What sucks is that I only had a couple thousand miles on that oil, I guess I have to change it seasonally?
I do seasonally but I do a lot of under water and soupy mud.. I usually swap my fluid for winter and then run it till winter or change it if I got it contaminated..
lets just hope whatever reason your fluid was so bad it didn't cause bearing damage.
I had a rebuild because of melted spider gears where all the bearings were replaced along with they spideys 6 or 7 months ago...maybe just breakin? idk
how did you manage to melt the spider gears? they don't move too much under normal circumstances.
Mobil-1
i got water in the differential and then drove cross country at 85 mph, they were nice and toasty! lol lots of steel shards and really deep ass pits in the spider gears, the shards shreaded all of the bearings and the vibration hollowed out my carrier
anyone else have a catastrophic experience like this lol
i blew couple of teeth on the ring and on the pinion as well.
how'd you manage that
it happened on the hwy, however when i took it apart there seemed that the preload on the pinion was gone (it had some play in it) so the gears didn't mesh properly and caused wear on the teeth.
This is the first time I've changed the fluid since I got the new spideys, bearings, and carrier....is it possible i'm just seeing resin/breakin material in the fluid :fitz:
you're supposed to replace it after 500 miles... yes there is a breakin time
Well it had been longer than that :yikes: idk, it cost 1k to fix it the first time, if it goes out again I guess I'll just go pull a dana 44 off a rubicon lol
.....if they screwed up my rear axle causing it to grind wierd, would it eat oil faster?
what do you mean by "eat oil"?
Grind weird? If they screwed it up you would know right away. Whining is what you'll normally get. Although there is really a lot of leeway when setting up gears. But then you have to properly break them in. If you have or had any questions about the work, I would recommend taking it back. When breaking in gears I typically use the cheap Napa brand. You'll be changing it out after 500 miles anyway. You don't really want to run synthetics for the break in though.
I mean burn and shear it out of grade and such, I have a couple of times and the first time they went "we don't know what it is and we don't care enough to crack it open" the second time I got them to take it apart and my carrier was hollowed out...maybe the new spider gears got broken in wierd because of the instability of the pin in the carrier. idk if my axle explodes and I die I'll let you guys know
it shouldn't burn unless the bearings are super bad and they generate a lot of heat. Same for the gears. Metal shavings a whole different story but the 2 could be related (but i would think at some point would break so if you put miles on it on a regular basis and didn't break down yet i would determine what's whining and fix it before it becomes unrepairable (could be a carrier or pinion bearing for example).
I just took a vid of it with my ipod strapped to my rear axle.....up close its like a nom nom nom while not under load and a metal on metal sliding noise under load.......does this help anyone?
Who ever set up your gears don't sound like they could pour piss out of a boot with the directions on the heal :flush:
And if your going to play in the water you need to change your fluids often.
If you're worried then you need to address the problem with the installer. Gears aren't that hard but when they are set up wrong they will go bad fast. Gears will run a bit hotter when they are breaking in though. I think they should be making any strange noises. While you're at it make sure your driveshaft bolts are OK and there is no play in the yoke.
What should I torque the U-Joint bolts to? I was thinking of taking 5 min and dropping the ass end of my driveshaft to see if the pinion nut was loose
grab the yoke and move it side to side, if it's loose you'll know right away
IIRC the straps are something like 15lbs.
Sorry for all the questions but how would I know that the pinion nut is loose lol
Grab the driveshaft near the yoke and shake it.
and just tighten until it doesn't do that anymore?
Well, if you have a crush sleeve for setting the bearing preload then you have to be careful not to overtighten it, but basically yes.
was it loose?
to correctly set the preload on the pinion bearings you need a new crush sleeve and to take the carrier out. If it has play then i say take it straight back to the shop that did the work.
I took recordings of my drivetrain at my Bellhouse, front axletube, and rear axletube and it's definitely something from the rear half of my drivetrain but I'm not sure if it's my differential. I'm going to take a video of my driveshaft and see if it's unbalanced or they reinstalled it incorrectly. I'll let you guys know when I figure it out.
Ok there wasn't too much play, but when you turn it it doesn't make that nice clean *dung* sound my frond diff does.....its more like a *clu-tunk* like the kid of noise when you shake a gun but deeper pitch. I know I'm kinda herping and derping on the descriptions but hay, also there's gear oil all over everything, it's all the way up on the yoke and pinion nut.
