General Forums => The Mess Hall => Topic started by: stevenu on March 20, 2011, 08:26:08 PM
Title: throttle body/ spacer
Post by: stevenu on March 20, 2011, 08:26:08 PM
I did the throttle body conversion and can tell that there is an improvement. Before the tb i had the spacer only and could not tell anything. i think it is worth the 55 dollars i spent on the part. i would say that if you wanted more outta the 4banger you might as well do it. it definitely doesn't hurt and there are plenty of places to potentially get it cheaper than i did or... spend more.
Title: Re: throttle body/ spacer
Post by: sharpxmen on March 20, 2011, 08:29:05 PM
what t/b did you get? is the spacer matching? (I mean if it is the same diameter as the t/b you just installed since you mentioned you had it before)
Post by: stevenu on March 22, 2011, 08:13:09 PM
yea i got a used 4.0l throttle body. it bolted right up with out any issues not even a issue with the idle. and yes the spacer is the same size. next will be the intake, im gonna open it up to be the same size as the tb/tbs.
Post by: stevenu on March 26, 2011, 02:33:05 PM
both throttle body and spacer are at 62mm still planning on doing boring the intake as soon as i get across country. like i said tho definetly an improvement.
