General Forums => The Mess Hall => Topic started by: pathfinder on February 23, 2006, 08:36:58 AM
I recently put a lift on my 2006 jeep wrangler rough country 6inches in the front and 4 in the rear i just like the front higher than the rearanyway my friend who put the lift in said there was a littl pinion vibration and not to worry most lift that high has a little vibration and its only going to 2nd 3rd then it smooth out is this a big deal or what my friend said he has a kit he could instaal but he don't like to unless he has to i guess its a bitch to put in,any way he said most lifted vehicles have soe what of a vibration also my speedo is off about 10 miles and hour because of the big tires is there any thing i can buy to fix this problem or just deal.thank you
pathfinder
If you're not lowering the transfer case and you're not cam'ing the rear diff, your pinion angles probably look bad.
I recommend doing it right the first time and not doing it half-assed. Measure the pinion angle. You'll either need to cam the rear axle back into spec and/or lower the transfer case. The better option would be to get a slipyoke eliminator and a CV driveshaft. In any case, the vibrations are caused by the driveshaft angle.
As for the speedometer check the FAQ.
