		General Forums => The Mess Hall => Topic started by: mrcabinet on June 14, 2011, 05:34:51 PM
				Now that the hot weather is here, I'm finally getting around to completing the flex-a-lite install I started last fall. It is complete except for the AC trigger wire. It says to hook it up to the positive side of the AC clutch circuit. Can someone point out where that is one the PDC?
 Thanks!
				what year is it? (can't remember, if it's a '95 i can look it up in the FSM, otherwise i don't know)
 you could also trace the color of the wire though, in case you can't find an answer here.
				On my '94 it was a blue wire running along the firewall on the main wire loom...
				2001 TJ
				2001 TJ
 sorry, can't help.
 Morris4x4 has online FSMs, you might want to see if you can find it there.
