Author Topic: See what you think  (Read 1518 times)
See what you think
« on: June 27, 2011, 08:30:11 PM »
Quote
2.5L 4 cyl, AX5 5 speed manual, NV231 transfer case
Have a noise coming from around the bell housing area. 1st, 2nd and 3rd gear and reverse. it's like a clicking, like roll your tongue to say "Bddddddddddddd". I put a brand new clutch in about 7,000 miles ago, and a used transmission. I'm thinking it could be one/some of the bolts that hold the clutch to the flywheel came loose, though I tightened them with a torgue wrench. It dosn't sound like the throw out or pilot bearings... but I just don't know. anybody have any ideas?
I asked him if 4th and 5th made noise and they do Not.
Re: See what you think
« Reply #1 on: June 27, 2011, 08:47:01 PM »
this is all considering that the noise is indeed coming from the bellhousing, if it's inside the transmission it's a whole different story:
- bad pilot bearing
- ask him if he clocked the flywheel properly (unlikely but seems that some people do that, not sure how though)
- the other thing i can think of is the inspection cover withouth some of the bolts
by the way he describes it i would think to be more of a driveshaft issue though.
