Author Topic: Steering box time?  (Read 4590 times)
Re: Steering box time?
« Reply #15 on: July 05, 2011, 02:06:09 PM »
The plug on top of the steering gear with the big nut on it can be adjusted
Here ya go, as long as the worm part where the balls roll does not have excessive play, you start with this then adjust the sector shaft.
This is step 2
Dine this way the box is adjusted correctly
Offline mrcabinet
« Reply #16 on: July 05, 2011, 05:45:11 PM »
I'll give it a whirl. Thanks!
Offline mrcabinet
« Reply #17 on: July 08, 2011, 07:06:41 AM »
So, night before last, I pulled the steering box off. On the bench, it was so tight that I could barely turn it with a socket and breaker bar on the shaft. That's when I decided that since my daughter would be driving the rig, I didn't want to take any chances with the steering. I hit the O'Reilly's by my house yesterday morning. Turns out that the manager there has a '99 TJ and he had never heard of the Durango swap. He was so intrigued by it that he sold me a Durango box for the TJ price ($30.00 less) and even matched Advance Auto's 20% on-line discount. He didn't care what I brought in for a core, so long as it was "a chunk of metal that looks like a steering box". While I was at it, I exchanged and replaced the rebuilt pump that had been growling since I put it in three weeks ago (third times a charm!).
All I can say is WOW! That thing drives like a sports car now! I guess I've been fighting the gear box for almost two years now, and I never would have suspected it if I hadn't had to replace the pump because the reservoir kamakazied onto the pulley.
For those replacing the box by themselves, I found that it worked great to put the nose end of it on a floor jack, rest the body against the tie rod and connect the lines before using the jack to raise it in place.
« Reply #18 on: July 08, 2011, 02:46:42 PM »
Well O a, glad you finally got a handle on it
