Author Topic: hp 44 swap  (Read 5345 times)
Re: hp 44 swap
« Reply #15 on: July 08, 2011, 03:39:08 PM »
Here is something to think of, if there is a fair amount of side play on the c clip axles it could push the caliper piston back on the 8.8 axle then you need a lot of fluid to push the piston back out to the point where it clamps the brake pads again.
If that is the case a master cylinder with larger pistons would help mask the problem
interesting point, i guess there's a reason the german cars have floating calipers  :wall:
you're probably right, that makes total sense.
to expand to that, can also happen if your front bearings go out of whack (same idea or even worse maybe)).
Re: hp 44 swap
« Reply #16 on: July 12, 2011, 09:31:40 PM »
Look at the SJ pitman arms when you get to that point, they're relatively flat and longer hole to hole than YJ arms.  I needed the longer pitman arm for the proper steering ratio with my BTF steering arms.
Re: hp 44 swap
« Reply #17 on: July 12, 2011, 10:54:08 PM »
that was a brain fart, the jeep ones are also floating (they are one side piston so they have to be).
